Rewiring passing lamps
Old Nov 14, 2007 | 02:05 PM
Windup08's Avatar
Windup08
Default RE: Rewiring passing lamps
Does anyone know if all the instructions noted above apply to the 08s?
Old Nov 14, 2007 | 02:10 PM
YodaddyKeith's Avatar
YodaddyKeith
I'll venture to say they do.....but ALWAYS probe to be sure no matter what the year or version and no matter what the factory service manual sez......Believe me, you don't want to fry the electrical harness....If you don't own even acheap VOM, then get one before you attempt ANYTHING electrical on your bike or car/truck..
Electricty is Pure Magic and it will bite you.
Old Nov 14, 2007 | 02:13 PM
oneshotdog's Avatar
oneshotdog
Thankyou yodaddykeith I appreciate the quick response
Old Nov 14, 2007 | 03:05 PM
MNPGRider's Avatar
MNPGRider
I first saw that diagram here in the lighting forum. I wish I had read the link that's posted on this thread. I, too, noticed the lights staying on with the ignition in the accessory position, necessitating shutting off the rocker switch for the passing lamps. I would have used the other suggestion of splicing it into the feed wire to the high/low switch, so it would automatically shut off with the ignition switch in the accessory postion.
Old Nov 14, 2007 | 05:09 PM
rome304's Avatar
rome304
try search section has a lot of good info on this subject.
motorcycleboy
2014-2024 Touring Models
Jun 9, 2014 09:50 PM
AndrewMichaelZ
Mar 7, 2011 08:37 PM
Tonus
Electrical/Lighting/Alarm
Nov 15, 2010 08:15 PM
quackhead
Mar 10, 2008 03:04 PM
rbcss
Dec 15, 2005 09:00 PM
