IDS install
Old Nov 15, 2007 | 04:56 PM
iclick's Avatar
iclick
Default RE: IDS install
Here's a quickly done, not-too-great photo of the area in question, shot from underneath looking up. Note the bumper should be visible as shown. If not, it is probably lodged somewhere between the swingarm and caliper.
[IMG]local://upfiles/4327/47DD53D227AB4484BB56C2C3E9BAEEE8.jpg[/IMG]
Old Nov 15, 2007 | 05:06 PM
Wes10RG's Avatar
Wes10RG
Thanks iclick, just printed it out and will check when I get home. Photo is great.
Old Nov 15, 2007 | 05:11 PM
redhill's Avatar
redhill
Hey, Just got to ride mine again. Has anyone gone over 80mph since they put the IDS on. Got my brake grommet straight, thought that was it. Right at 80mph my bike still vibrates the foot boards pretty good. Before 80 and after 80 it does not.. Does anyone else have that symptom?? Thanks..............
Old Nov 15, 2007 | 05:20 PM
brentf's Avatar
brentf
Thanks Iclick, I haven't recieved my IDS yet but it should be any day now . I will certainly look for this.
Old Nov 15, 2007 | 05:36 PM
reneb3's Avatar
reneb3
Mine is smooth as glass at 80. Or any other speed over about 65. With the vibration at only one speed it sounds like a harmonic caused by something rotating out of balance. Tire maybe?
Old Nov 15, 2007 | 07:01 PM
iclick's Avatar
iclick
ORIGINAL: redhill
The RPM at 80mph (speedometer) should be around 2850 RPMs. Does it vibrate at 2850 rpms in 5th gear? IOW, is it RPM- or speed-related? Check your mufflers to make sure they haven't moved backward, as if they go back far enough they can touch the mount metal-to-metal. If you had to remove your muffler to remove the axle for the IDS job and re-used the clamp, that might be the cause of the vibration. HD clamps are designed to go through one tightening cycle, then tossed, as they may not clamp tight enough again. I had trouble with my right muffler and couldn't solve it with new clamps, so I rigged a second rubber grommet in front of the standard one to keep the muffler from sliding backward. When my muffler moved back to make metal-to-metal contact on the rear mount I got a similar vibration at about that RPM, but mostly at heavy throttle.
lmz5150
Shovelhead
Jun 1, 2019 01:33 PM
spooneralmighty
Wheels/Tires
Aug 16, 2012 09:32 AM
stro1965
Jun 21, 2010 10:53 PM
Bldr1000
Mar 14, 2008 09:00 PM
barkster99
Sep 17, 2007 07:46 AM
