Engine Shaking-2000 Ultra
Old Nov 15, 2007 | 01:07 PM
Punisher's Avatar
Punisher
Default RE: Engine Shaking-2000 Ultra
sounds like your bike is working fine...
Old Nov 15, 2007 | 01:38 PM
jbhawley's Avatar
jbhawley
i bet it shakes becasue you are not using genuine HD oil or have a over heating problem.
WHy not start a new thread about the oil adn overheating. I dont ever recall that being discussed on this forum.
Old Nov 15, 2007 | 01:55 PM
ken thompson's Avatar
ken thompson
The Schlong Man
Does it shake like mine? Be proud my friend.
Old Nov 15, 2007 | 02:00 PM
PeteM's Avatar
PeteM
ORIGINAL: jbhawley
How's about winterizing?
Old Nov 15, 2007 | 02:01 PM
PeteM's Avatar
PeteM
ORIGINAL: ken thompson
Your's seems like it is loose in da back, mine feels more like da front
Old Nov 15, 2007 | 02:56 PM
Comfortably Numb's Avatar
Comfortably Numb
oh no...this is a bump....as this post needs to be seen....its indicative of the new HDF....i love it....my motor is shakin
Better a question that's been asked a million times from folks that won't use the 'search' function, than a million inane replies to an equally inane post from all the post ****** that lived here in the past.
Cn
Old Nov 15, 2007 | 03:55 PM
miacycles's Avatar
miacycles
Once again make sure that all the motor mount bolts are tight. Then have the compression checked, if there is a significant difference between the cylinders that will cause it to shake. If the difference is significant you need to do a leak down to help pinpoint the problemThen check your wires, spark plugs and injectors if you have them. Lastly if you got around 30-40,000 milesyou might want to check your lifters.
Old Nov 15, 2007 | 05:28 PM
sugarbear's Avatar
sugarbear
ORIGINAL: miacycles
Sorry but it's a harley it shakes.
Old Nov 15, 2007 | 06:49 PM
jaymcgil19's Avatar
jaymcgil19
Try not to hold the front brake on when stopped. This will help reduce some transmitted vibrations.
Old Nov 15, 2007 | 09:24 PM
Bryan TTM's Avatar
Bryan TTM
why thanks.....i enjoy you as well
ORIGINAL: Comfortably Numb
Cn
