timing chain tensoiners
Old Jan 19, 2008 | 01:50 AM
  #41
twistedcherokee's Avatar
twistedcherokee
Default RE: timing chain tensoiners
Anyone have the bearing puller & installer for the cam bearings in the case around Colorado Springs, Co ? Or the best place to buy them? Thanks
Toby
Old Jan 19, 2008 | 09:23 AM
  #42
2005UltraNC's Avatar
2005UltraNC
Lost ya - what are you able to pull apart by hand? If the bearing/cam assembly into the cam plate - then "no" those bearings should not just fall out (would then think about replacing the cam plate).
Old Jan 20, 2008 | 10:14 PM
  #43
twistedcherokee
The bearing in the cam plate is still in but the cam that goes thru and the sprocket goes on, once unbolted it slides out of the bearing.
Toby
Old Jan 20, 2008 | 11:42 PM
  #44
chuckk01's Avatar
chuckk01
no comment.
Old Jan 21, 2008 | 09:38 AM
  #45
tarheelrdr's Avatar
tarheelrdr
The rear cam, the one w/ roller bearings will slide out , at least they did on my 04 ultra and 03 wideglide. Only the front cam has to be pressed out and then the bearings. I think this is correct.
Old Jan 21, 2008 | 10:04 PM
  #46
twistedcherokee
I will try to take a pic of the bearing that I am talking about tomorrow. Chuckk01, whats with the no comment?
Toby
Old Jan 21, 2008 | 10:15 PM
  #47
Taterdog's Avatar
Taterdog
Didn't have to press anything out of my camplate. Flipped it over, tapped one of the cams lightly with a soft mallet, and both cams/bearings fell out of the cam plate. If the bearings do happen to stay in, just put the camplate with bearings in the oven, 300F for 30 minutes. The camplate is aluminum and will expand greater than the steel bearing -- should be able to tap out then -- if they don't fall out. Use a socket same size as bearing housing.
Old Jan 22, 2008 | 10:39 PM
  #48
twistedcherokee
Thanks Taterdog. That answers one question. Guess I will buy the bearing puller & installer for the bearings in the case.
Toby
Old Jan 24, 2008 | 05:42 PM
  #49
Taterdog's Avatar
Taterdog
ORIGINAL: twistedcherokee
Toby
Sorry, Toby, been out of town a few days. You can buy the tool for the inner bearing, or rent it. I rented from Perry Barth at
pbarth@cableone.net. E-mail him and he can send you his price list. Much less expensive than buying.
Jim
Old Jan 26, 2008 | 02:05 AM
  #50
twistedcherokee
Thanks Jim. I emailed him. Not like I am going to ride right now, my drwy is still snow packed and roads still have ice.
Toby
