"Pings" @ Elevation
Old Nov 18, 2007 | 10:15 PM
unclekunkle's Avatar
unclekunkle
Default "Pings" @ Elevation
My (Calif) '07 (stock) Roadglide pings purty bad ridin 2 up when pullin grades above about 7000 feet in elevation. Anybody know if the dealers are addressing this problem with maybe an updated flash that might modify the ign timing?
Old Nov 18, 2007 | 11:24 PM
atexn4christ's Avatar
atexn4christ
Default RE: "Pings" @ Elevation
I had the same problem when I was using Arco gas. Switched to Chevron hasn't happened since. They were both 91 octane by the way.
Old Nov 19, 2007 | 12:00 PM
rkcrwlr's Avatar
rkcrwlr
My 07 did it around 7K also. Did not work well for me as I ride 6 to 10K elevation and back regularly. Dealer could not tune it out. I finally went stage1 and have no more issues with pinging.
Old Nov 19, 2007 | 09:35 PM
unclekunkle
I tried all different fuel brands with no effect. This "pinging" occured only when traversing the Rockies coming and going to Sturgis. I bought some octane booster and added a little with each fill up, which "minimized" the ping but didn't make it go away entirely. I've ordered a K&N high flow air cleaner and the Vance and Hines Fuelpak to complete my stage one but I got the following reply from Fuel Pak Technical Support:
"The fuelpak will most likely not eliminate the pinging under a load. Pinging is a real issue with the 2007 models and can only be fixed with 02 eliminators and timing adjustments which the fuelpak isnšt capable of."
I'm just wonderin if anyone's heard if Harley has a timing adjustment fix for the ping short of aftermarket mods ?
Old Nov 19, 2007 | 10:40 PM
StreetglideOK's Avatar
StreetglideOK
TMax or DTT maybe, instead of eliminating sensors?
Old Nov 19, 2007 | 11:47 PM
rkcrwlr's Avatar
rkcrwlr
Depending on the date of manufacturing, there was a dealer download to help with pinging. Applied to the early 07s, but I am not sure if it works for CA models.
edit - it applies to those before 11/1/06. Do a search on here for the "07 recall" and you'll find a lot of info on it. Still don't know if it applies to you though.
Old Nov 20, 2007 | 02:37 AM
TOMCENTRAL's Avatar
TOMCENTRAL
TMax My buddy has
one & it helped his bike loads.Regards,Tom
Old Nov 21, 2007 | 12:34 AM
unclekunkle
ORIGINAL: rkcrwlr
Good call...good info. I'll be contacting the dealer soon.
Old Nov 21, 2007 | 06:20 AM
HogBack's Avatar
HogBack
As you suspect...there is something really wrong here.... Yourmotor should ping less at higher elevations... Predetonation with 91 octane fuel at 7000, isreason to camp on the HD dealers doorstep....
Later
Hogback
Old Nov 21, 2007 | 06:29 AM
continentaldrifter's Avatar
continentaldrifter
At what RPM does the pinging start?
