Replacement Shocks
Old Nov 22, 2007 | 12:42 PM
White Knight 04's Avatar
White Knight 04
Default RE: Replacement Shocks
I went with the 11 1/2 shocks and I am very pleased....
Old Nov 22, 2007 | 06:26 PM
jeepster09's Avatar
jeepster09
ORIGINAL: Overdoo
What is the difference between the 412"s and the 440 series. Is there any benefit to either series.
[IMG]local://upfiles/45755/893AFFD78CC04E079A36F3B8F9173637.jpg[/IMG]
About $300.00 bucks, I have used both and like the 412's.
Old Nov 28, 2007 | 09:19 PM
CROWLEY's Avatar
CROWLEY
Hello again,
I've read in the suspension section the following post:[/align]
To mount the shocks, a jack is nice but not necessary. If you don't have a jack, use the following method.
You will change the shocks one at a time. To remove the right shock, set it to the lowest preload setting and set the left shock to the highest setting.
Can I do this with the stock air shocks on my FLHTCUI?
I want low1/2 inch with Progressive 12.5"
matt_eglide
Mar 25, 2015 10:43 AM
Jager247
May 17, 2014 05:49 AM
85RoadsterXLS
May 31, 2013 06:49 AM
46and2
Jun 20, 2011 06:22 AM
mgg126x
Feb 25, 2008 09:31 PM
