horsepower&torque
Old Nov 23, 2007 | 05:33 PM
rdmhouston's Avatar
rdmhouston
Default horsepower&torque
i would like to get some opinions and thoughts,i just had a 103 installed with stock compression,i also had a sert, and se 204 camsand rhineheart true duals with the 2 i/4 baffels and a full map done on the dyno,this is an 08 ultra,after all this was completed i am only seeing about 89 hp and about the same in torque this seems a little lite to me does anyone have any suggestions,is the tuner in questions does he know what he is doing,i also had the se air cleaner installed
[/align]
Old Nov 23, 2007 | 05:51 PM
clg9mm's Avatar
clg9mm
Default RE: horsepower&torque
What heads?
Old Nov 23, 2007 | 05:54 PM
2005UltraNC's Avatar
2005UltraNC
How does it ride? Fuel mileage?
rdmhouston's Avatar
rdmhouston
i am sorry that i did not say so but stock heads
[/align]
Old Nov 23, 2007 | 05:58 PM
rdmhouston's Avatar
rdmhouston
runs and rides great,i haven't checked fuel mialege yet,i also had a oil cooler installed,it sure runs a lot cooler
[/align]
Old Nov 23, 2007 | 06:25 PM
Ram's Avatar
Ram
Need heads with port work and larger 50mm SE Pro EFI throttle body.
After that addDTT.
Old Nov 23, 2007 | 06:43 PM
chornbe's Avatar
chornbe
*snicker*
Old Nov 23, 2007 | 07:04 PM
asuperheat's Avatar
asuperheat
seems low on tq, the 95" I was running was 94 tq with 203 cams, I have never looked in to building a 103" but I havent seen a lot of 103" with a 204 cam mostly 257, 258 again im not sure on this but I would check to see if the 204 is a good match with the 103".
Old Nov 23, 2007 | 07:14 PM
monkish's Avatar
monkish
I am not a motor man so I am not sure what is or isn't good but this is what I have as of last week.
Thunder Header 2/1
SERT
Big Sucker
HQ-TC-500-HC cams
No head work
82 HP / 93 TQ
This actually may change tomorrow asthey got the tune a little on the lean side and I am taking it in for adjustments in the morning. I will have it back in the afternoon.
Old Nov 23, 2007 | 08:58 PM
vettedog72's Avatar
vettedog72
I have the same additions but stock cams on my 103 police motor. I don't have the numbers at hand but I recall the torque is close and your HP is6or8 points higher than mine. My MPG is 41 to 50+.
