Floorboard extension brackets
Old Nov 25, 2007 | 02:26 AM
Rodent's Avatar
Rodent
Default Floorboard extension brackets
I notice that on Soos's floorboard extension bracket, there are only two mounting holes and on the Harley Goodies bracket, there are six holes. Could anyone that has mounted either kit, explain if the other four holes on the HD Goodies bracket will ever be used? Why have six when you will only need two. I'm confused. Could either sponsor explain? Thanks in advance.
Old Nov 25, 2007 | 04:05 AM
tjmac49's Avatar
tjmac49
Default RE: Floorboard extension brackets
I have the Harley Goodies floorboard extensions installed; the 6 holes match-up with the 6 holes on the stock bracket. They allow you the option to change the angle of the floorboard; Played with changing the angle; left it in the original setting.
Old Nov 25, 2007 | 09:43 AM
soos's Avatar
soos
ORIGINAL: Rodent
Hey Rodent,
I did experiment with a multi hole bracket and in my opinion found that it was unnecessary to have more than 2 holes for adjustment. As tjmac49 pointed out, he left it in the original setting which is where the majority of riders leave it.
I went with the 2 hole design and shorter bracket because it matches the length of the mounting surface of the jiffy stand bracket on which it is placed when installing. (Note pic below) It provides the support needed for the footboard. When in place, the bracket is virtually invisible and because I make my kit from aluminum there is strength without additional weight.
[IMG]local://upfiles/4575/A298BD5DA3654A8AA49C715772DD8D87.jpg[/IMG]
Old Nov 25, 2007 | 11:38 AM
brshrideevo88@aol's Avatar
brshrideevo88@aol
soos' product is Great...buy it if at all thinking of it. He's a great guy to deal with..No, I am no way associated with him, I have just dealt with a very helpful guy.
roundy
Oct 6, 2016 10:52 AM
flhxs103
Dec 15, 2015 05:00 PM
inkedup7
Dyna Parts
May 28, 2015 01:21 AM
fxdxruss
General Topics/Tech Tips
Mar 22, 2014 11:54 PM
harleyheaven
Feb 29, 2012 10:38 AM
