"DIY MODS" and TRICKS to SAVE $$$$$$
Old Jan 12, 2008 | 10:17 PM
  #141
iclick's Avatar
iclick
Default RE: "DIY MODS" and TRICKS to SAVE $$$$$$
ORIGINAL: kjtoys
Creepshow I like your license plate relocation idea.My question is how do you get the main license plate bracket of the rear fender.Do you have to go under the rear fender? Thanks Kerry you have a great looking glide.
The best way to get at the nuts that attach the license bracket is to remove the tail light. First remove the lens, unplug the four blade connectors on the back, and then two bolts that attach the tail light reflector. Once the light is removed you have a large hole from which to access the area where the nuts holding the license bracket are located.
Old Jan 13, 2008 | 08:21 AM
  #142
kjtoys's Avatar
kjtoys
thanks ill try that
Old Jan 17, 2008 | 07:07 PM
  #143
big_al's Avatar
big_al
I just installed a shortie antenna, I bought it at the auto parts store and it cost $6.98 plus tax. I am sure that someone else has done it but I thought I would share anyways. At least the bike does not look like a remote control scoot...
[IMG]local://upfiles/45508/4737F25100D94BFFADBECAAA58021EE5.jpg[/IMG]
Old Jan 18, 2008 | 09:18 AM
  #144
mllkn6's Avatar
mllkn6
How is the reception, is it as good as with the whips or not as good? I'm thinking about doing the same thing and adding a booster unit if needed, so I'd like you know if I need the booster. Thanks.
Old Jan 18, 2008 | 03:47 PM
  #145
big_al's Avatar
big_al
I live and ride in the miami metro area, the reception is perfect, miami is as flat as a pankake not mountains or hills to deal with, it works 100% no difference..
Old Jan 20, 2008 | 05:31 PM
  #146
HarlyFan's Avatar
HarlyFan
Save your money instead of buying these short antennas just remove the stock and cut the bottoms of to whatever length that you like............
Old Jan 20, 2008 | 08:07 PM
  #147
Wally's Avatar
Wally
The ones on my tourpac where cut off when I bought the bike. They work fine.
Old Jan 21, 2008 | 08:27 PM
  #148
Razerman's Avatar
Razerman
The top ofthe aluminum oil dipstick looked plain,, I took my state quarter
layed iton a thick towel-------hit the back side with a pin punch----that made
the face of the quarterrise up and gave it the curviture of a dome,,fits nicely
over the dipstick with high temp RTV silicone--now I can pick my bike out of the crowd.
..well at least before I told you guys,,,,[sm=oopssign.gif]
Old Jan 21, 2008 | 08:47 PM
  #149
mvinc01's Avatar
mvinc01
ORIGINAL: Razerman
Interresting...Gotta pic of it?
Old Jan 22, 2008 | 11:10 AM
  #150
harleykris's Avatar
harleykris
I put a powered antenna inside the fairing and the reception seems fine. Out of site, and cleans up the bike a bit. While on a trip last year, some ******* broke off my shorty antenna and left it lying on the ground by the bike, with the American flag still attached!
