"DIY MODS" and TRICKS to SAVE $$$$$$
Old Aug 6, 2008 | 02:50 PM
  #271
Uncle Scrooge's Avatar
Uncle Scrooge
Default DIY bottle holders
Here are water bottle holders for EG, both driver and passenger. I had clamps to fit one inch bars in my odds and ends. Use one on handlebar for driver or two on saddlebag guard top and bottom for passenger. Insert 3/8 inch threaded rod through the clamps. Bolt 3/16 eyebolts to the bottle holders and slip onto threaded rods with nuts to hold in place. I used some old Profile brand holders, but any bicycle bottle cage will do.
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-120_2099.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-120_2097.jpg
Old Aug 6, 2008 | 11:07 PM
  #272
ben67zl1's Avatar
ben67zl1
There is a site on web shows very similar style jack using 2X6 and some pipe with a piece of pipe insulation to keep pipe off bike, also won't let bike tip jack backward
Old Aug 8, 2008 | 10:49 AM
  #273
007 ultra's Avatar
007 ultra
Default Light in the tour pac
Needed a light in the tour pac but didn't want to spend the bucks HD wants for their setup.
Went to AutoZone, purchased a glovebox light with intregrated switch for about $3.00. Mounted the light with doubleface tape to the lid of the tour pac near the lock. Ran wire down into the tour pac and taped in place with black Gorilla tape - then to a hot lead and a ground.
Open the lid, flip the switch and there is adequate light to see whatever is needed in the tour pac.
This job didn't take very long and did not cost much other than the purchase of the light with an intregrated switch.
Happy riding.
Old Aug 8, 2008 | 10:54 AM
  #274
007 ultra's Avatar
007 ultra
Originally Posted by pkenyon1
In UK the Harley Siren comes as stock...loud as loud can be.
I dont know where HD get off switching these things around...on UK model the tri bar light on the rear fender is a blank and we have to buy that light.
They just love to mix things up to keep taking your coin!
Maybe there are more thefts in the UK??????
Just asking is all.
Old Aug 10, 2008 | 09:27 PM
  #275
jimonline's Avatar
jimonline
5th Gear
Default too simple fix for tour-pak cable
Got tired of the cable getting caught when I or someone else closed my tour-pak. Added a light weight crimp on fishing line weight. Works better than perfect.
Old Aug 11, 2008 | 05:36 PM
  #276
artc's Avatar
artc
On the cable in the tour pack. Rotate one end 180 dregees and reinstall. It wooked 4 me...
Old Aug 13, 2008 | 07:52 AM
  #277
bugeater's Avatar
bugeater
3rd Gear
Default Garage opener
This would have been my suggestion, also. I got my momentary contact switch from Radio Shack. When I had a FLHT I mounted the switch on the dashboard and left the large out-sized button on top for easy access and it acts like an umbrella for the switch during rain or washing, the opener was tucked into the fairing. Now, with my FLTR I mounted the switch on the inside of the remote lever of the rider seat back adjuster, and the opener sits under the side panel.
A downside for wiring an opener to a OEM accessory switch is that if for some reason it got left on, or someone else flicked it on, the opener battery would run down fairly quickly.
Old Aug 13, 2008 | 11:28 AM
  #278
Yesca's Avatar
Yesca
Default DIY Mod for broken fuel tank to intake quick connect
New to Forum, so here is my DIY Tip that I hope others can benefit from:
Here is a cheap replacement for the fuel tank-to-intake quick connect for fuel injected models in case the factory one gets broken and you don't want to pay $45.00 + dollars for a new factory piece of plastic & fuel hose .
Dorman p/n 800-120 is for a steel quick connect (5/16") ~$10.00 at auto parts store. Or Dorman p/n 800-057 for a plastic replacement quick connect fitting (5/16") w/nylon tube attached that can be cut off and removed ~$20.00 at auto parts store.
I used the steel one on my '07 FLHT and it works fine, no leaks.
Old Aug 25, 2008 | 10:50 AM
  #279
longmc's Avatar
longmc
Stage I
Default Brake Light Strobe
A guy on a 2008 Ultra-Classic pulled up at our local HD dealer and when he pressed his brake lights, there was to lights strobing in red. When asked what they were, he informed me he was almost hit by a drunk driver and put these strobes under his trunk. He stated people do not get as close to him anymore, especially when he activates his brakes.
Well guess what? I went and bought one. I mounted it above my tail light. It is so powerful and will definately let people behind you know you are stopping.
Here is the manufacturer. Look for the Axixtech Exterior / Surface Mount LED Model (4s Series). http://www.brookingindustries.com/products.php
They LED's come in RED, BLUE, AMBER, and maybe a couple of other colors. Chrome or Black housing.
Old Aug 26, 2008 | 08:26 AM
  #280
Hawgnut's Avatar
Hawgnut
Default what a good idea
Originally Posted by CREEPSHOW
Glad to see this section growing still. Been a while since I been in here so here ismy latest. Custom floorboard, well I will say, covers. Check it out!
https://www.hdforums.com/m_2891935/tm.htm
What did you cut them out of it looks great !!! I'm with you on making stuff up your self. Going to the stealership isn't good for the wallet
