"DIY MODS" and TRICKS to SAVE $$$$$$
Old Dec 21, 2007 | 11:35 PM
  #61
mvinc01's Avatar
mvinc01
Default RE: "DIY MODS" WAY TO GO :)
ORIGINAL: harley_504
lay down license plate for flht. Used a dremel to raise the holes in the bracket. Used a bench grinder to grind down the bolt heads until very thin and cut a screwdriver slot in them. Reinstalled and now I have a laydown license plate bracket for about 15 mins of work. No $$$$
Pics 4 & 5 - This mod worked great for me too. Did it tonight. Thanks harley_504. It was something on my list from the catalog that will not cost me the $50. It was free.
Pic 3 - is a CD holder in my left side bag. It's one of the car visor holders that I cut the elastic straps off of, placed adhesive velcro on it and the insid of the bag, and stuck it on. It's removable if I need to and fits great! Also out of the way.
Pics 1 & 2 -are where I decided to mount myMP3 player(Creative Zen VisionM 30 gig). Used heavy duty velcro from WMT and ran a 6' aux audio cable up through my tank dash, down in front of the tank, zip tied to the main harness, and up in front of the neck to the stereo. Pretty clean and I like how it looks. Easy to use too.
I just bought my bike not too long ago, so I have not done much to it...yet.
I really like this thread. It needs to grow...keep'em comming!
[IMG]local://upfiles/26031/692467DFDAF04A43A64F9D5FD0A33B8F.jpg[/IMG]
[IMG]local://upfiles/26031/352B94CFDF004E498AA637E264B8509B.jpg[/IMG]
[IMG]local://upfiles/26031/A5BD16A193F04E94B6F4816059374D1F.jpg[/IMG]
[IMG]local://upfiles/26031/F701B40133304BAAB2534CDA576D16FF.jpg[/IMG]
[IMG]local://upfiles/26031/82C6232F688D4CF9AD694F7341AB5E27.jpg[/IMG]
Old Dec 21, 2007 | 11:39 PM
  #62
mvinc01's Avatar
mvinc01
ORIGINAL: Erdnase
I carefully pulled the reflectors of my bag latches, cleaned off the doulbe stick tape, sanded down the back side to remove the form marksand lightly painted them gloss black. I then reapplied them to the opposite side (since they are mirror image,) black out with double stick tape. Reflectors gone and it looks much better. Cost ZERO!
I would also like to see a picture of this.
Old Dec 22, 2007 | 01:50 PM
  #63
CREEPSHOW's Avatar
CREEPSHOW
ORIGINAL: mvinc01
ORIGINAL: Erdnase
I thought about doing that but found inserts cheap on e-bay!
[sm=ttiwwp.gif]
Old Dec 22, 2007 | 04:16 PM
  #64
BGHFD's Avatar
BGHFD
Hey Fast Eddie,
How well does the garage door opener work from under the dash? I have Craftsman opener, and they seem to be a little weak.
Thanks
Old Dec 22, 2007 | 07:08 PM
  #65
2008FLHP's Avatar
2008FLHP
I don't know if this qualifies as a DIY but; take an old 5qt oil container, cut the side out and lay it down to use to drain your fluids...fits under the bike no problem
Old Dec 22, 2007 | 07:22 PM
  #66
mvinc01's Avatar
mvinc01
ORIGINAL: 2003FLHPI
It's simple, but still a good tip. I'd say it qualifies. Antifreez jugs work good for this too. Cut them so the handle and screw top/spout stay intact. Also makes a good parts cleaning bowl so you don't use all your wifes good tupperware out in the garage.
Old Dec 23, 2007 | 07:46 AM
  #67
XfasteddieX's Avatar
XfasteddieX
ORIGINAL: BGHFD
Hey Fast Eddie,
Thanks
it went from working about 1 block from the house to 1/2 block from house
Old Dec 23, 2007 | 10:12 AM
  #68
texas steve's Avatar
texas steve
For $89 I added two Polk Tweeters to my Hog Tunes and they make a WORLD of difference!!
Close UP
Old Dec 23, 2007 | 10:22 AM
  #69
Rodent's Avatar
Rodent
How did you hook up the wires for the tweeters? Do they just tap into the Hogtune speaker wires?
Old Dec 23, 2007 | 10:28 AM
  #70
texas steve
ORIGINAL: Rodent
The Tweeters come with a crossover for each one, and I simply soldered the crossover lead to the Hog Tunes speaker wires on the speaker spades. I tie wrapped the tweeter crossovers (there about the size half a deck of cards) to one of the big wire harness in the batwingjust to hold them in place. The crossovers are totally covered with epoxy so not to worry about shorting etc.
Easy mod, and great sound.
