"DIY MODS" and TRICKS to SAVE $$$$$$
Old Jul 21, 2012 | 07:34 PM
  #1061
Glockmeister's Avatar
Glockmeister
Originally Posted by CREEPSHOW
Many people are switching to the spun aluminum gauges. The standard has a couple gauges with just a black plug in the hole.For those who are missing a gauge or two from the set here is an idea tochangethat ugly black plug into a spun aluminum look!
Most of us have changed out the timing cover for something else and if not most of the time people will give them away or for little money. The inside ring of the stock timing cover fits almost perfectly inside the plug. All you have to do is trim it down to the inside ring. First, cover the middle with some tape and trim it with a razor blade. I used tin snips to cut the edge offbut it wanted to bend the thin cover so I would try another method of triming it. After the bulk was gone I ground the edge with a bench grinder. To fine tune the edge, I used a drimmel with a grinding stone and finished it off with a file. A little automotive adhesive (3M tape would work) and there you have a spun aluminum plug!Make sure to position the plug in the fairing first (goes in one way) and then attach the aluminum piece making sure it is straight up and down!
Here is a couple pictures of how it looks both on and off the fairing. Cost $0
Update
Ok, so this didn't match my gauges well.. Stood out like a sore thumb!
I painted it with that flat black BBQ paint and then used thinner on a shop ragand very carfully rubbed the paint off the raised area. Looks alot better for my application
Those look awesome!
Old Jul 25, 2012 | 06:29 AM
  #1062
kyle90's Avatar
kyle90
Saved 60 dollars by buying speaker carpet and spray adhesive and lining the saddlebags myself. It didn't turn out bad at all. Also bedlined the bottom of the bags(just incase something spilled.
Old Jul 25, 2012 | 09:22 PM
  #1063
fenderzig's Avatar
fenderzig
Do you have any pics?
Old Jul 26, 2012 | 06:19 AM
  #1064
Gunslingertom's Avatar
Gunslingertom
I have some pics of a tour pac I did recently if interested. Same material and method.
https://www.hdforums.com/forum/evo-c...pac-lined.html
Old Jul 26, 2012 | 05:50 PM
  #1065
Thorshammer's Avatar
Thorshammer
Cool Cheap riser mod
Guys, This mods is from another site that helped start several years ago. Started out as a site for VTX's but some of us have HD's too. Heres a link for a great riser mod, the sizes my be different but you'll get the idea. I ran these on my heavily modified VTX with no problems and they looked awesome.
http://i253.photobucket.com/albums/h...ocketMod-1.jpg
Old Jul 29, 2012 | 09:39 PM
  #1066
Corter1433's Avatar
Corter1433
2nd Gear
Awesome holder, doing this next weekend
Old Jul 29, 2012 | 10:05 PM
  #1067
fenderzig's Avatar
fenderzig
Looks great, Tom. Thanks!
Old Jul 30, 2012 | 03:44 AM
  #1068
allthecoolnamesrgone's Avatar
1st Gear
Originally Posted by BigBrainBob
OK, I am the king of morons so it idea of cut to fit wire to work a garage door opener will happen in my next life time. I have a 2011 Road Glide Ultra which happen to come with heat shields by the seats, well there was enough room on the inside of the shield to just velcro my opener to it. Yeah yeah it may get too hot there but I'll see, if so I'll die and come back and wire it to the acc switch, for know the cost was zero and the job was like 3 min max (one sip of the can of beer .
If that doesn't work Ill drill a hole put a switch right on shield and but the opener under the seat, something about drilling holes in my fairing doesn't sit right. Thanks big time for all of the DIY's
All this chat about blokes drilling holes in their bikes, there's no going backwards then!
Old Jul 30, 2012 | 10:56 AM
  #1069
White Ice's Avatar
White Ice
It's only a bike - metal & plastic. It has no soul.
I've drilled into my inner fairing twice. Once below my voltmeter for a garage door opener switch, and once above the speedo & tach for my gps Ram mount.
The holes haven't affected performance or gas mileage yet. The engine doesn't leak and the tires hold air. My gps & door opener are within easy reach. All is good.
Old Jul 30, 2012 | 10:44 PM
  #1070
ndabunka's Avatar
ndabunka
Thanks for the tread. Good read
