draining fuel,,
Old Dec 1, 2007 | 08:34 AM
electaRICK's Avatar
electaRICK
Default draining fuel,,
I might store my bike at this place that requires fluids to be drained,,,
whats the best way to empty the gas out of a EFI ultra??
nope , cant ride!
Old Dec 1, 2007 | 08:37 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: draining fuel,,
ORIGINAL: electaRICK
nope , cant ride!
The only place down South that requires fluids to be drained is the funeral home. Is this something you guys are considering up North now you cheap bastage?
Old Dec 1, 2007 | 08:39 AM
BadBobOk's Avatar
BadBobOk
See page 4-3 in the service manual.
Old Dec 1, 2007 | 08:43 AM
electaRICK's Avatar
electaRICK
ultra,,, ahhh, I imagine, us boys "Uphere" with at least a high school education,,, know enuff to not have gas in heated storge units,, its a saftey measure,,, should you have know of this, all your grandaddys wouldnt have blown up cookin their brew in them thar hills...
beside,,,, I cant let 6 gals of gas go to waste, I cuold use it in the snowblower,,, $3.50 a gallon you know!!!
oh yea,, thanks for the tip!!!!
I'm gonna get even you know!! :-)
Old Dec 1, 2007 | 08:50 AM
Rocket Jockey's Avatar
Rocket Jockey
Rick,
Phil Tip #234: You will have to disconnect at the crossover, which is the fuel line that connects the two sides of the tank and runs under the tank at the front. Get a 2' piece of fuel line (I think it is 3/8" id but check) and a bolt the same as the fuel line id. Get a gas can. Very quickly, disconnect one side, plug the crossover with your thumb and slip the fuel line over the expose fuel nipple and have the other end in the gas can. That will drain into the gas can. Slide the bolt into the fuel line your are blocking with your thumb. You will have to drain the other side too because a little gas will be left. That empties the gas tank but does not purge all the fuel from the EFI system. Your fuel rail will still be under pressure. Make sense? I would still run some Stabil through the system before draining because fuel is still in the system.
RJ
Old Dec 1, 2007 | 08:51 AM
UltraKla$$ic
Do all of that while smoking a big stogie of course. Nothing like a good sweet Cuban stoge while draining the tank!
Old Dec 1, 2007 | 08:53 AM
electaRICK's Avatar
electaRICK
OK,,, now that was a response!!! (hint u-cla$$ic)
thanks,, sounds ez enuff.
I was thinkin the fuel line,,, but like this better!
owe ya one! thanks again
BillyO's Avatar
BillyO
Store it someplace else. My barn is good-Concord,NH.
BadBobOk's Avatar
BadBobOk
The hose that you will need is 5/16" ID.
Old Dec 1, 2007 | 08:55 AM
electaRICK's Avatar
electaRICK
thanks Bob
rwven
2014-2024 Touring Models
13
Jun 7, 2017 10:46 AM
Davidandjune.viola@comcast.net
Mar 10, 2012 09:39 PM
Windup08
Jun 16, 2011 08:17 PM
Keithhu
Oct 25, 2010 09:34 AM
juniors05RK
Exhaust System Topics
Nov 25, 2007 07:18 PM
