Rush/Fuel Moto custom baffles
What about next steps...cams, big bore, heads etc? Can this setup (minus the slipons) grow with those types of upgrades and a new map?
Glad to hear you still like the purchase. I'm just learning to figure out this stuff, and your guys input is greatly valued.
Thanks again!
Cool! Thanks Bob. I was just looking at that multifunction hub and map switch on Dynojet. Is that was you have mounted on your bars? Did you add anything else to the system, like the LCD display, ignition module,or the gear position/speed input? I don't think I would need any of that at this time, but I do like the idea of being able to switch between a couple different maps (AZ summer vs. winter, or fuel milage vs. max performance).
[IMG]local://upfiles/4327/65C8E4B90A2F490587F8570A2E5A1569.jpg[/IMG]
Second, I don't think you need a map for mileage vs. max performance, as after 20% TP the maps are identical. Nail the throttle with one and it's the same as nailing it with the other. The beauty of the map switch is being able to run a lean map that won't heat the bike up while moving, and another for those times in summer when you are stuck in heavy traffic. I have noticed that there is quite a delay in flipping to Map 2 (richer) and seeing results (lower oil temps), so I try to anticipate the need and switch early, like well before the off-ramp before you get into heavy traffic. It isn't a panacea, but it helps--and I would definitely install an oil cooler first.
I did mount a borrowed LCD display for about one day and it gave me some useful info on TP at various cruising speeds, but I wouldn't pay $300 for one. Besides, the display is dim and hard to read in sunlight, and it isn't waterproof. There is also no mounting hardware in the kit, and I don't know where you'd permanently mount it. I had the borrowed unit velcroed to the dash on the gas tank, but that wouldn't be a good permanent location, IMO, as to see it you'd have to take your eye too far from the road.
There are other functions on the hub, but I don't know what I might use for this bike. I had thought about running the voltage readings from an O2 sensor into the analog input of the hub and allow an LCD display to log the readings, showing TP, RPM, and O2 voltage--but I haven't given too much thought to the connection process. For example, I don't know where to get an HD O2 sensor connector to rig this up properly. This logged info would tell me the A/F at any given TP and RPM, which would be very useful info if I could figure out how to rig it up. I could also do the same thing by using a voltmeter, although I understand voltage fluctuates rapidly on an O2 sensor which might make it difficult to read on a meter, especially while riding. That's why a logging feature would be useful for this.
Excellent informationBob! Thank you very much for taking the time for such a great write up!
I think for the buck, this will be a great improvement for my bike, making me happy, and my bike happy.
thanks again. Now, just a couple more Christmas presents for the kids and wifey...then it's MY turn HAHA HOHO.
This deffinately sounds like a good setup for me to do, with the summers out here. What oil cooler did you run? I think I'm gonna be very happy with Jaimies set up and an IDS install.
I recommend Jamie's kit, but don't expect it to be obnoxiously loud, because it isn't. For me it is perfect, and I couldn't ask more of a stock engine in the way of performance. As for IDS, that's another big thumbs-up if you own an '07 FLH!
Rabid
(just about to pull the trigger)
