Fork Lowering
Old Dec 2, 2007 | 11:24 AM
jpmflying's Avatar
jpmflying
Default Fork Lowering
I had the rear lowering shocks installed on my 08 UC when I bought it. I am considering installing the front fork lowering kit myself. Do I need special tools or can someone with reasonable wrench turning abilities do it?
Old Dec 2, 2007 | 07:16 PM
dawg's Avatar
dawg
Default RE: Fork Lowering
You can fab most of the tools that you need.
Old Dec 2, 2007 | 07:39 PM
SiLlY's Avatar
SiLlY
This won't be that helpful but I remember cutting some PVC pipe for some reason.
Old Dec 2, 2007 | 07:53 PM
dawg's Avatar
dawg
ORIGINAL: SiLlY
2" PVC, that would have been for seating the new seals
Old Dec 2, 2007 | 08:54 PM
mopar7's Avatar
mopar7
If you have wrenching skills then it will be a piece of cake. One trick I did slide your new seal on then flip your old seal and slide it on top of the new one. Use a 1 ½ PVC coupling on top of the old seal and slide hammer the new seal into position. Works like a charm.
Old Dec 2, 2007 | 08:59 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Would RECOMMEND PROGRESSIVE Ft LOWERING SPRINGS over the HD's
Old Dec 2, 2007 | 09:19 PM
SiLlY's Avatar
SiLlY
Thanks Dawg, that was it.
I remember having trouble re-filling them too. Some might want to give tips on that.
Old Dec 2, 2007 | 10:31 PM
rk1121's Avatar
rk1121
I installed the HD spring lowering kit on my 07 rkc. Piece of cake except for compressing the fork springs. You will need to come up with something for that, usually a combination of bench vise and floor jack. Or, you could spend $250+- for a special tool. Once it is all put together you will be happy with the ride, which is more than I can say about the shorter air shocks (sucks).
ARTZWAKEN
May 28, 2016 08:16 PM
rounder
Nov 9, 2009 01:41 PM
ShooterSteve1953
Mar 15, 2009 09:58 PM
wrenchguy24
Sep 24, 2008 08:04 PM
wideglidebob
Dec 7, 2006 10:54 AM
