Internal antenna??
Old Dec 6, 2007 | 08:47 PM
crashbike310's Avatar
crashbike310
Default RE: Internal antenna??
Bought the one from eglidegoodies. I get more stations than I used to. I have to find a better ground. Sometimes when I hit the brakes the radio gets scratchy. But a great improvement over my shorty
Old Dec 6, 2007 | 08:48 PM
greg09997's Avatar
greg09997
Get the powered one. Is only $20- and it works better with the Weather band.
There's a free power source coming off the headlight tree.
Old Dec 6, 2007 | 08:52 PM
hoz88's Avatar
hoz88
Great! Thanks for all the ideas.
Old Dec 6, 2007 | 09:15 PM
Storm_law's Avatar
Storm_law
I got an amplified antenna from Crutchfield Electronicsfor around 20 bucks.You can check it out by clicking here.
It works well, although AM is not as good. It is not as good as the Stock Whip Antenna for AM but it does the job. FM and Weatherband work perfectly.
I did a write up on my Blog about the Antenna that you can read by clicking here. You will have to scroll down in the article to where it says: "What to do with the Stock Whip Antenna?" to read my review of the hidden antenna.
I like Crutchfield because they have good customer service, they ship quick, and they will allow you to return the part if it does not work.
With my removable tour pak setup the hidden antenna was the only way to go!
Old Dec 7, 2007 | 12:52 AM
sifularson's Avatar
sifularson
ORIGINAL: Storm_law
Just read your Blog on installing your tourpak. Great stuff. Funny thing is I just did the same thing on my bike just a few days ago. Took a lot of courage to drill those 14 holes in a brand new tourpak. I got by a little cheaper however. I bought an aftermarket copy on Ebay for just over $300. It's a fiberglass exact copy. Also bought the rack and backrest on ebay. Have $570 total into mine not counting the mounting hardware.
Steve L.
Old Dec 7, 2007 | 05:59 AM
TickTock's Avatar
TickTock
Tune Trapper. I have used both the powered type and the Tune Trapper on the same bike. The Tune Trapper brings stations in much crisper in my opinion.
Old Dec 7, 2007 | 06:54 AM
avcaruso's Avatar
avcaruso
http://www.ecshylites.com/page/page/761353.htm
Here is what I have - works great great - even gets the weather band!!!!!
Old Dec 7, 2007 | 07:23 AM
Blackisfast's Avatar
Blackisfast
ORIGINAL: Storm_law
Same here...works great as I never use AM.
Old Dec 7, 2007 | 09:23 AM
Erdnase's Avatar
Erdnase
I just moved the bracket down to the next available position, ran the whip up under the seat and tank. No cutting no problem and I still get good reception.
Old Dec 7, 2007 | 09:39 AM
radridd's Avatar
radridd
Replaced my powered unit with the tune trapper. Much better now and also get WB
