08 BRAKE ROTORS??
Old Dec 11, 2007 | 12:27 PM
jag1886's Avatar
jag1886
Default 08 BRAKE ROTORS??
Does anyone know physically what is the differance between 08 rotors and 07 rotors?
I see they have a new part# for 08 on the front but I don't see any new #'s for the rear did they do anything differant on the rear?
Old Dec 11, 2007 | 12:29 PM
hoosierhog88's Avatar
hoosierhog88
Default RE: 08 BRAKE ROTORS??
I'm guessing here, but it prob'ly has to do with the new Brembo brakes on the '08 models.
Old Dec 11, 2007 | 12:32 PM
extech's Avatar
extech
They call it a semi-floating rotor, dimensions are the same as 00-07.
Old Dec 11, 2007 | 12:36 PM
jag1886's Avatar
jag1886
I know the new bikes have Brembo brakesI am looking for the (physical differances).
I'm trying to see if they would fit an 07 model.
Old Dec 11, 2007 | 12:44 PM
Chief X's Avatar
Chief X
Former Sponsor
The 2008 Touring models have a semi floating rotor to reduce brake chatter and increase brake pad longevity. The size has been slightly increased to a 300 mm diameter. The Softails and Sportsters still run the same rotors as in the past.
The reason for the new rotor on the touring models is for both the new calipers and the option of anti-lock brakes.
Hope this helps!
Old Dec 11, 2007 | 09:44 PM
FastHarley's Avatar
FastHarley
Former Sponsor
As stated before, 300mm. as far as sime floating, can someone please try to move these rotors side to side. If they move, than they are floaters. That is what floating rotors do is float. Now if they don't move are are hard attached they are just 2 piece rotors. Floating rotors are used when brake rotors get hot and are allowed to move in between the pads. A very good thing. You be the judge. This is a photo I took @ Phil Petersons HD, N. Miami, FL
[IMG]local://upfiles/29413/4C8917A9F5F341E5985D0E38D2112BAF.jpg[/IMG]
Chopperbob
Nov 17, 2012 07:34 PM
harley-jones
Oct 26, 2010 04:48 AM
AaronOregon
Jan 8, 2009 07:58 PM
Rocket_Rider
Nov 3, 2008 04:05 PM
SILVERTEX
May 17, 2008 09:05 PM
