Will IDS work on 06 eg classic?
Old Dec 13, 2007 | 02:47 PM
HDSAE60's Avatar
HDSAE60
Default Will IDS work on 06 eg classic?
I replaced the belt with a chain. and just wanted to know ifIDS will work, if so would it be better,for theengine,or fora smoother ride?
Old Dec 13, 2007 | 02:52 PM
DonnyI's Avatar
DonnyI
Default RE: Will IDS work on 06 eg classic?
IDS kit is for '07's only.
NICK56's Avatar
NICK56
NEVER HAPPEN
Old Dec 13, 2007 | 02:53 PM
NICK56's Avatar
NICK56
REPLACED BELT WITH A CHAIN ????? WHY>>>??????
I SMELL SOMETHING !
Old Dec 13, 2007 | 02:55 PM
SoCal_Pappy's Avatar
SoCal_Pappy
REPLACING your belt already???? WOW... They normally last 50K or better if ya keep then adjusted...
AustinRider's Avatar
AustinRider
you shouldn't need it on the '06... IDS is available to correct a noise that is related to the six-speed tranny that came out on the '07.
Old Dec 13, 2007 | 02:58 PM
GlennsGlide's Avatar
GlennsGlide
I also am interested in this post,from what I've learned the belt is wider on a 07-08 model which would mean that a front pulley would also have to changed.
As far as if the IDS would fit up to a chain I have know idea. I think if you could actually marry up the system it should smooth things out a tad which is the effect I would be looking for.
Come all you knowledgeable types give us some opinions.
GlennsGlide
Old Dec 13, 2007 | 02:59 PM
89FLHT's Avatar
89FLHT
IDS is there to help compensate for the "redesigned" compensator in the primary that really doesn't work that well. Your 06 doesn't need it.
Old Dec 13, 2007 | 03:05 PM
NICK56's Avatar
NICK56
THE ONLY CHAIN IN THIS STRING IS THE FACT THAT I BELEIVE SOMEONES IS BEING YANKED !
Old Dec 13, 2007 | 03:14 PM
HDSAE60's Avatar
HDSAE60
ORIGINAL: SoCal_Pappy
Man I wish it would have lasted longer, butafteronly 20kI had a lot of stone damageto the belt and pully system. and never been off the pavement.
