remove my skins
Old Dec 18, 2007 | 01:42 PM
bigmack's Avatar
bigmack
Default remove my skins
going to remove my skins on my 03 rkc to get painted any tips will be helpfull or do i need any special tools
Old Dec 18, 2007 | 02:25 PM
Cannon00000's Avatar
Cannon00000
Default RE: remove my skins
what are the "skins" do you mean tins?
Old Dec 18, 2007 | 02:47 PM
Harleypingman's Avatar
Harleypingman
Most folks don't have a 36mm wrench/socket for the rear axle, and the rear tire must be removed (or at least dropped) to reach the front bolt of the rear fender.
Old Dec 18, 2007 | 03:07 PM
planewrench's Avatar
planewrench
ORIGINAL: bigmack
You won't need any really special tools to remove the 'tins', except for that big wrench for the rear axle. You will be removing both wheels and tires and disconnecting fuel lines and electrical wires from the gas tank. What you DO need is a FACTORY shop manual. Forget that Clymer's junk. The manual will walk you through every step and provide the proper torque specs to put it back together correctly. You'll be dealing with some critical fasteners and you want to be sure they're tightened correctly. At least with the Classic, you won't be dealing with dismantlinga fairing.
Old Dec 18, 2007 | 03:18 PM
SoCal_Pappy's Avatar
SoCal_Pappy
"TINS" straight forward R&R... Just make sure the fuel tank is all the way empty as it can lead to a mess (lol)
Old Dec 18, 2007 | 04:57 PM
bigmack's Avatar
bigmack
ok tins, skins its all the same
SteelCityRider
May 31, 2015 03:19 PM
Captain W
Dec 21, 2011 12:49 PM
johnsa28
Aug 12, 2011 02:46 PM
slowhand
Sep 5, 2008 10:48 AM
mkink
Nov 14, 2005 09:54 PM
