compensator nut ?
Old Dec 21, 2007 | 03:40 PM
Biggzed's Avatar
Biggzed
Default RE: compensator nut ?
You may not be able to tell it's loose by looking at it. Mine was loose enough to hear the knocking sound and I still needed a breaker bar with a pipe on the end to break it loose. (insert your "time to hit the gym weakling" jokes here).
Old Dec 21, 2007 | 04:14 PM
tarheelrdr's Avatar
tarheelrdr
Can you here the knocking better at idling, I have a knock in mine and not sure where it's coming from. Doesn't do it as soon as I start it up, but in a few seconds it starts to knock. Could this be the problem?
Old Dec 21, 2007 | 06:42 PM
Bobzilla's Avatar
Bobzilla
Probably and after it warms up it quiets down a bit man it had me freeked out . just bought the bike in july and it started knocking in october it was 2005 RG took it to the steeler guy new exactly what it was and still charged me 80.00 bucks I think Iwill go back and ask about the bulletin If I am reading this right they are supose to fix it for free ?Well I suppose I could find a little bling for 80bucks or so !
Old Dec 21, 2007 | 07:08 PM
pled55's Avatar
pled55
a friend of mine had the knocking noise going on
said it sounded like the bottom end was coming apart
turns out comp.nut loose
by the way if haven't read this wrong is your bike 88in
or something different ?decent numbers for what you have listed
just wundrin
Old Dec 21, 2007 | 07:30 PM
pop1's Avatar
pop1
what a rip off
Old Dec 21, 2007 | 07:40 PM
framer's Avatar
framer
96
Old Dec 22, 2007 | 04:48 PM
AtkRWC's Avatar
AtkRWC
I think this is what I'm hearing. Might pull the side and take a check...
Old Dec 22, 2007 | 04:58 PM
blackonly's Avatar
blackonly
Is there a certain Yr. or model that we all should be concerned about..?
Old Dec 22, 2007 | 05:18 PM
framer's Avatar
framer
I have a copy of the service bulletin right here, I'll scan and post it later this evening. It's basicly what Twincam said: Touring,Softail and Dyna models 2003 through 2005
Old Dec 23, 2007 | 07:19 AM
blackonly's Avatar
blackonly
Thanks RKC
