SD Tri-Star XP turn signal module wiring.
Old Dec 22, 2007 | 12:54 PM
Lenyaw's Avatar
Lenyaw
Default SD Tri-Star XP turn signal module wiring.
I installed a Signal Dynamics Tri-Star XP turn signal to brake light conversion module on my 05 Ultra Classic and have had no success getting them to work properly. When hooked up according to their installation instructions, with the ignition on but motor not running, the turn signal lights come on bright as if the brake function is activated instead of just running lights. Turn signals work properly when turned on at this time. Hitting the brakes does not light any of the turn signal lamps as they are supposed to.
Once I start the motor (with turn signal still active) the turn signal stops flashing and still stays brightly lit (as if brake was activated) but still nothing when brakes are applied. [sm=confused06.gif]
I have triple checked to verify I have it wired properly but still no go. Removed signal wire from brakes to see if they would dim down to just running light brightness with no improvement. In my latest phone conversation with them, they stated that problem could be with the main harness running too close to the high voltage spark plug wires, causing static in their modules circuitry. The main harness is run along the same frame rail under the tank as the spark plug wire to the rear cylinder with just the rail separating them.
Let it be known that this is NOT a knock on Signal Dynamics products or their customer service. I have successfully installed both their Diamond Star headlight modulator and the BackOff brake modulator. They spent over half an hour on the phone with me troubleshooting an issue I had with the BackOff installation while they helped me find my error of tapping into the wrong wire. [sm=oopssign.gif] (Damn colorblindness [sm=smiley23.gif]strikes again!!) Customer service has been nothing but first class and I’m extremely happy with the way both modules perform.
Sorry for the long post but the bottom line I’d like to know is if anyone else has had a problem like this and if you were able to fix it?
Koonass31
Jul 7, 2009 10:52 PM
robbie68
19
Dec 30, 2008 09:56 PM
Joe376
Jun 5, 2008 07:28 AM
gpodwis
Jun 9, 2007 08:21 AM
AggieWildcat
Apr 27, 2007 11:16 AM
