stereo, CD guestion
Old Dec 22, 2007 | 05:28 PM
dobber709's Avatar
dobber709
6th Gear
Default stereo, CD guestion
I have a 07 ultra classic, i need to know if anyone has had problems playing burned cd in there stereo, when i play a burned cd it plays but then it stops for a couple seconds then plays again, it does that over and over. I have no problems playing real cd only does it with burned cd's.
Is there a certain type of rewritable cd's thati have to use?
Thanks
Tommy
Old Dec 22, 2007 | 05:56 PM
ultra man's Avatar
ultra man
Default RE: stereo, CD guestion
First of all make sure you have the latest software version, 8.19, I believe. Mine did that but on all cd's but only riding in the cold(40's).
Old Dec 22, 2007 | 06:28 PM
Rides2007Harley's Avatar
Rides2007Harley
I have a 08 and haven't noticed any problems. In fact, I burned a MP3 disc last night and it worked perfect.
Old Dec 22, 2007 | 06:53 PM
mtbag's Avatar
mtbag
Haven't had any problems with my 07 Classic, plays them fine.
Old Dec 22, 2007 | 07:01 PM
dawg's Avatar
dawg
I've had that problem with burned CDs before
Old Dec 22, 2007 | 07:10 PM
lkr0's Avatar
lkr0
I have had that problem many times before; I have pretty much solved by burning them with the software on Yahoo music--for some reason the HK unit likes that burn as opposed to the other burn software.
Old Dec 22, 2007 | 08:04 PM
goodbirds's Avatar
goodbirds
It is more likely a software problem. Some files are corrupted before the burning onto a CD, and the player hits them and stops. I used rewritable cd's (CD-RW).
Old Dec 22, 2007 | 09:27 PM
YodaddyKeith's Avatar
YodaddyKeith
I do music big time. I've built my own DAW(digital audio workstation) andburned several thousand CD's, but there was a distinct learning curve involved.
Start with a top quality burner like a Plextor, then use top quality discs, and of course the best software.....Nero 6 is one of the best.....Once I got those items, no more coasters.
Oh, and make sure you got plenty of RAM and also shut down all other unecessary programs before you burn.
Here's my music station:
Old Dec 22, 2007 | 09:29 PM
captjon37's Avatar
captjon37
If you have a acc plug on your radio go get a mini mp3 player like the sanse clip ($44.00 for 2gb at best buy) and load it up with music. A little double stick tape and short wire from radioshack and no more changing cds.
Old Dec 22, 2007 | 09:38 PM
dirtdobber's Avatar
dirtdobber
I have noticed-discussing with other riders-that certain year models require different blank disc's.
Try a different type disc. I have problems with the black disc's but a friend has problems with the ones I use. If that is not it check for a update. My radio plays everything but black disc's and and not all causes me problems.
