LED tail light at dealer. Yes, from Harley. have 1? what do you think? Is it brighter.
White lens cap, red led's. It is a plug and play at a cost of 140.00.
Any one out there that has bought 1? Is it brighter?
Worth the the 140.00 dollars?
Zanottis has an inventory page where you can look up a part# to see if they have it in stock too. I just can't vouch for the lists up to date status. https://www.zanottimotor.com/HdInv.pdf
Here's is my take: Mine cost $105.00 on my previous ride, and was a card that plugged into the bulb. IMO it was excellent at night, brighter, but not in the daylight. They may have improved by now....
I have the new HD LED for 08, part #68087-08 (Smoked Lens w/ Black Housing) and it looks awesome on my Black SG. The smoke turn lenses completes the setup. Only the inner housing is black, the mounting bezel is crome. Pg 508
Shows the inner crome housing ---> http://*******.com/38cpev
I should have mentioned that the lens has built in white license plateLED's that light up the top of the fender and especially if you have a backrest installed. This is only an issue with the Street Glide. I'm going to try to find a work-around to either disable or black them out. Otherwise I will have to return it as it's really quite bright and I'm sure I'll get a ticket for improper lighting.
[/align]
I bought one for my 07 roadglide. It has the clear lens and chrome mounting bezel and it's very bright. I like it. Two mounting screws and a push in connector and it's installed. Real easy.
