It will work fine but it may take a while to add any significant amount of air to a tire. The air suspension pump only gives out small fuffs of air per stroke.
So far I have only used it to adjust the shocks...wasn't sure if it would hurt it or not on the tires..I have a compressor at home I was looking for something while traveling if they needed to be topped off...
Take a close look. It is nothing more than the guts from a 10 buck compressor, like I have in my hand, a bit of wire, a hose, a switch, and a fitting. You can make your ownon-board air set upfor less than 50 bucks.
I got the valve cap from the tires and suspension system mixed up and they woudn't interchange I just assumed it would not work. Will the suspension pump fit the tire valve stem?
