Smart Siren II Install - 2008 FLH
Old Dec 31, 2007 | 07:05 PM
Skivvy9r's Avatar
Skivvy9r
Default Smart Siren II Install - 2008 FLH
Hi!
I just bought a Smart Siren II (part #68328-06) to add to my 2008 Ultra. But the instructions that came with it don't take into account MY08 changes, specifically the move of the ECM from the right side. Has anyone installed one ofthese in their '08?Does it still install underneath the ECM chassis? Thanks for your help.
Old Dec 31, 2007 | 10:46 PM
Skivvy9r's Avatar
Skivvy9r
Default RE: Smart Siren II Install - 2008 FLH
Okay, I figured it out. There's a place to install the siren under the left side cover to the left of the fuse box. The cable to connect it runs under the fuse box, plugged into a dummy connector at the lower left corner of the fuse box. The fit is tight but it will go in. Learn something new every day.
Old Dec 31, 2007 | 10:51 PM
MustBBrent's Avatar
MustBBrent
So, is the install an easy install and something you recommend? Or was it convoluted or complex or worse, just down right did not work and needed some McGivering (sp?)?
Old Dec 31, 2007 | 10:59 PM
rick867's Avatar
rick867
just installed mine yesterday,went in real slick,also got the rechargeable pager system,also works great
Old Dec 31, 2007 | 11:21 PM
Skivvy9r's Avatar
Skivvy9r
Very easy install, once you know where it goes. I would put it in the novice category. Took more time reading the instructions than I did installing.
Old Dec 31, 2007 | 11:27 PM
DZLDR's Avatar
DZLDR
It's so easy, even a Cave Man could do it!!
klaybus
Mar 12, 2011 08:56 PM
capt42a
Aug 25, 2008 01:56 PM
capt42a
Aug 15, 2008 09:40 AM
tatuaje
Feb 26, 2008 09:41 PM
YAREMASI
May 19, 2006 08:35 PM
