Changing Windshield on FLHT
Old Jan 3, 2008 | 11:21 AM
IamZardoz's Avatar
IamZardoz
Default Changing Windshield on FLHT
I was thinking of changing windshields on my 07 FLHT. Did a searchbut didnt find anything about how to so Ill just ask, is all you have to do loosen or remove those three torqz screws and the windshield slides in and out? Any tricks I need to know before attempting? Thanks in advance.
Old Jan 3, 2008 | 11:25 AM
07blackcherryflhx's Avatar
07blackcherryflhx
Default RE: Changing Windshield on FLHT
correct. Loosen them and wiggle the sheild out. The sheild does fit over tabs on the inner fairing. Work each side at a time and be gental. Its a peice of cake.
Old Jan 3, 2008 | 11:26 AM
jakedog's Avatar
jakedog
So simple even a RUB can do it!
Old Jan 3, 2008 | 11:30 AM
UltraKla$$ic's Avatar
UltraKla$$ic
If I do any work near the front end, I cover my front fender with a towel. The three screws across the top of the fairing are what needs to be loosened beginning with the 2 on the outer edges first saving the middle for last. Keep your hand on the windshield and just lift out. Inspect rubber trim that lays against the glass on the inside of the fairing for missing sections or sections that will eat up your windshield and change if need be.
Old Jan 3, 2008 | 11:45 AM
IamZardoz's Avatar
IamZardoz
Thanks for the input, just ordered a new Cee Bailey ice blue tinted windshield and tinted headlight armor (for my spotlights to change from clear to yellow).
Old Jan 3, 2008 | 12:00 PM
nvsteve's Avatar
nvsteve
Be sure to use the correct torx and don't over tighten.
Old Jan 3, 2008 | 12:06 PM
rome304's Avatar
rome304
good project to start also get a look inside fairing for future ideals.
Old Jan 4, 2008 | 06:58 AM
Peppa1's Avatar
Peppa1
Good time to add that chrome windshield trim piece too !!!
Old Jan 4, 2008 | 08:52 PM
IamZardoz's Avatar
IamZardoz
Yep, picked up the plain chrome windshield strip from the dealer today, $39 for a single strip of chrome and three screws! I ordered a Cee Bailey windshield (stock size but ice blue tint) and also ordered the yellow running light armor so that should look pretty good I think when I get it all installed. Ill take a few pics when I get it all installed.
Old Jan 4, 2008 | 08:59 PM
soos's Avatar
soos
ORIGINAL: IamZardoz
Yeah, Cee Bailey's is a good choice. Now if I could only remember where I saw one [sm=confused06.gif]
