Rush 2.5s vs Rush/FuelMoto
Old Apr 15, 2008 | 06:15 PM
Scootr's Avatar
Scootr
Default RE: Rush 2.5s vs Rush/FuelMoto
I'm still debating on this set up. I already have the rush pipes/bs/pciii so I may try it out. Keep us posted on the results.
Old Apr 15, 2008 | 06:21 PM
CKinAZ's Avatar
CKinAZ
Interesting note about his kit. One pipe is restricted to a 3/4" hole and the other is a 2.0" hole. Combined area of these two holes is 3.58 sq. in.
Combined area of two standard 1.5" baffles is 3.53 sq. in. A reduction of 0.05 sq. in. Not enough to really change things IMHO.
Why post this? Because cross sectional area has a great deal to do with flow capacity. There may be some scavenging advantages to the pseudo 2:1 from fuelmoto that allows for better performance than dual 1.5's, but only testing would quantify that.
As for dual 2.5's, my guess is that the head pipes are the flow limiters and that scavenging is greatly reduced because the headpipes effectively dump into open air since the baffle diameter is so large. That might be good for a high rpm race motor, but can't be good at all for low/mid torque....
I've done a little playing with exhaust systems in the past. Just thought I'd throw some of that out there for you all to chew on.
Old Apr 16, 2008 | 04:30 PM
iclick's Avatar
iclick
ORIGINAL: CKinAZ
Bigger isn't necessarily better, and simply comparing exit areas doesn't cover all the bases. Keep in mind the left side has a reversion cone, which apparently helps with scavenging over and above the second pipe alone. When Jamie was experimenting he told me he tried dozens of combinations, including different size reversion cones, even with the left muffler completely plugged. When we talked it was a week or two before he released the kit and he was very excited about the results he was getting on the dyno. That excitement was contagious and I ordered the kit as soon as it was available.
This combo provided the best HP and TQ, and it is definitely stronger and quieter than my previous 1.75" setup, both in low-end TQ and peak HP. I can see this on Jamie's chart and also feel it in the seat of my pants. I'm very happy with it and wouldn't change anything, except perhaps to add a mild cam, but that's not a short-term goal. As well as this engine runs I may just leave it alone.
Old Apr 16, 2008 | 04:49 PM
montanatinman's Avatar
montanatinman
I just installed the fuel/motokit Monday.... So far so good.. Definate improvement in sound... I may have to lean it up a little for mileage according to some other posts that I've read here. Snowed the dayI installed it so hopefully I'll get to do the seatof the pants Dyno Friday.
Old Apr 16, 2008 | 04:58 PM
montanatinman
You may want to ask Jamie about the modified K&N air intake he came up with. Apparently some members have had trouble with oil belching back into the air cleaner on the standard K&N, his is supposed to cure this. I went with the Arlen Ness Big sucker
Old Apr 16, 2008 | 05:05 PM
iclick's Avatar
iclick
ORIGINAL: montanatinman
I'll probably get this AC myself after living with the K&N 3909 for over a year. Jamie's custom job is apparently a modified HD SE with a cleanable element. I don't think there are any K&N parts in this kit. He told me it would eliminate the oil barfing on my saddlebag guard bags, which is getting on my nerves.
Old Apr 17, 2008 | 11:59 AM
llmotorcycles's Avatar
llmotorcycles
We have put his kit on several 07 and 08s and to me this is a near perfect combination of sound and performance.
Benielsahn
Jan 20, 2014 08:20 PM
Geezr Glidr
Jul 27, 2011 05:05 PM
HBomb74
Jul 27, 2010 05:12 PM
barkster99
Jun 10, 2009 01:51 PM
robertj74
Sep 9, 2008 11:03 AM
