Question #1:
I just got set-up with an LED turn signal set. Now I purchased the kuryakyn adapter to plug the resisters into so hopefully that will slow down the blink. Part numbers are 4810 for the resisters and 4837 for the harness. Will the Harley Run/Turn/Brake module affect the way the LEDs work and are these to kits compatible?
Question #2:
I just bought a Sundowner seat for my FLHX and am wondering if the seat, being as wide as it is, will rub on the back side of the saddle bag lids?
I put all leds on mine. I didnt use the kury load resistor , i used Biketronics and I also have Biketronics Run, turn, Brake.
Short answer yes it will work but your load resistor needs to be downhill of your R,T,B mod.
