Inside the fairing projects
Old Jan 5, 2008 | 04:38 PM
gwcrim's Avatar
gwcrim
Default Inside the fairing projects
The bike is an '07 Ultra.
I've got the fairing apart to install new handlebars this winter. I'm also doing the "driving lights on all the time" mod and hiding the satellite radio antenna and wiring. I was considering doing the garage door opener mod, but I just hang my opener on my clutch cable and use the same on in the car as well. No big deal.
What else should I consider doing whilst the fairing is apart?
Old Jan 5, 2008 | 04:40 PM
biz44's Avatar
biz44
Default RE: Inside the fairing projects
A new pair of speakers to replace thos so so OEM units??? I got the JBL 527....or something like that, and they kick a$$. Or if you dont mind spending a $100 or so a pair....go for the Hawg Wired........perfection!
Old Jan 5, 2008 | 04:42 PM
cirhere2's Avatar
cirhere2
painted inner fairing, hog tunes
Old Jan 5, 2008 | 05:40 PM
sifularson's Avatar
sifularson
Have you thought about oil temp gauge?
Old Jan 5, 2008 | 05:44 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SPEAKERS
OIL TEMP GAUAGE
HIDDER ANTENNA
Old Jan 5, 2008 | 05:49 PM
BLACK 3's Avatar
BLACK 3
check the speaker brackets
they break near the speaker scews
Old Jan 5, 2008 | 05:50 PM
ragingbull's Avatar
ragingbull
Upgrade the headlight...
Old Jan 5, 2008 | 05:58 PM
RonH's Avatar
RonH
put a Hogtunes amp in there and speakers in the lowers
Old Jan 5, 2008 | 06:11 PM
Harleypingman's Avatar
Harleypingman
Well, all of the above are excellent suggestions. When I installed a painted inner fairing and spun aluminum gauges it was like getting a new motorcycle when I rode it because what I saw in front of me was so different from the stock set-up.
Also, fairing mounted mirrors may work well for you.
Old Jan 5, 2008 | 06:27 PM
tombeving's Avatar
tombeving
While you have the fairing off, get a tube of electrical connector sealant and coat the inside of the connectors. Protects against corrosion and makes them easier to take apart the next time
