engine light on again
Old Jan 7, 2008 | 12:18 AM
PapaTravis's Avatar
PapaTravis
Default RE: engine light on again
Not that this could in any way help, but... my truck was throwing a warning light every time I got up to 3k RPM, then would go out when I let off the gas. Turned out that the altenator was going out. Still worked a bit, but was not charging to the full capacity. Wasn't there an issue with the regulators on the '07's?
Old Jan 7, 2008 | 08:03 AM
texas steve's Avatar
texas steve
ORIGINAL: fastolds
Fourth time of this happening on my 07 FLHTC. The last one they said was a bad plug wire. It seems to happen when I rev it up over 4500 RPM going down the road. What gives?
This happened to me on my 07FLHX. After checking the codes what I found was it was always on the rear cylinder. After checking each timeit turned out that the spark plug wire (where it connects to the spark plug) was pulling off the screw cap on the spark plug. So it was just sitting there and barley making contact.When you went fast (high RPM) it would vibrate enough to casue a problem. At low RPM no problem
So, check your plug topscrew that goes into your plug wire, make sure it is tight etc.
Old Jan 7, 2008 | 09:23 PM
fastolds's Avatar
fastolds
I will check it out.
Old Jan 7, 2008 | 09:33 PM
bigdoghd's Avatar
bigdoghd
What Glide said is correct for self diagnoses, trouble is the average person is not going to know what to do with the info when that get it. Hell a lot of the techs don't know what to do with the scanner let alone dvom meter. If the bike is under warranty take it to another dealer if your in Illinois area drop me a line and I'll see if I can help ya out. I think someone mentioned the lemon law...it does not apply to motorcycles in the state of Illinois.
holli4pirating
Engine Mechanical Topics
Aug 5, 2015 10:24 AM
zworld
Apr 28, 2012 08:56 PM
ardbark
Oct 4, 2008 03:00 PM
06bob
Aug 8, 2008 11:29 AM
Harley Dave69
Exhaust System Topics
May 7, 2008 05:56 AM
