Exaust flange nut torque??
Old Jan 8, 2008 | 05:48 PM
rzbigdog's Avatar
rzbigdog
Default Exaust flange nut torque??
I just installed a new exaust system today. I put new crush gaskets in and I was wondering what the correct torque values on the flanges are?
I have a foot lb torque wrench so If it is in lbs what would the conversion be?Thanks
Old Jan 8, 2008 | 05:52 PM
rzbigdog's Avatar
rzbigdog
Default RE: Exaust flange nut torque??
sorry i should have said what bike i have. 2007 Street Glide.Thanks again
Old Jan 8, 2008 | 05:53 PM
eglidetrike1's Avatar
eglidetrike1
If you use a 1/4 inch ratchet set up, just make it good and tight.
Old Jan 8, 2008 | 06:02 PM
soos's Avatar
soos
By the numbers, 100-120 in-lbs.
Old Jan 8, 2008 | 06:43 PM
Retired_Ted's Avatar
Retired_Ted
Go back and forth slowly and evenly to make sure they're torqued the same. Too much torque will snap 'em off, btw.
Old Jan 8, 2008 | 06:45 PM
hogbag07's Avatar
hogbag07
I just checked my manual 100-120 in-lbs is what the 2007 service manual states but that soundsto tight . I bet that would snap a stud go by feel
Old Jan 8, 2008 | 06:54 PM
rzbigdog's Avatar
rzbigdog
thanks for the quick replies.I torqed them down at 7ft lbs.I think 120in.lbs is 10ft lbs of torque if i am correct.so maybe I should retorque them at 10ft lbs.Im confused????
Old Jan 8, 2008 | 07:37 PM
soos's Avatar
soos
ORIGINAL: rzbigdog
1 ft-lb = 11.993 in-lbs. So 7 ft-lbs = 83.951 in-lbs.
Old Jan 8, 2008 | 07:45 PM
MJR's Avatar
MJR
Good job soos.
Old Jan 8, 2008 | 08:09 PM
rzbigdog's Avatar
rzbigdog
Do you think i should just leave it alone at 7 ft lbs or should I do the 10ft bls? I havent started the bike yet because im waiting for my PCIII from fuel motto.So I want to have everything as close to spec as I can.
