Front Fender Removal
Old Jan 10, 2008 | 09:10 PM
07blackcherryflhx's Avatar
07blackcherryflhx
Default Front Fender Removal
I have an 07 street glide and I am trying to remove the front fender. I have the front wheel off the axel I thought the wheel would just drop right down. Ha well I was wrong. The tire is to big to pass the brake calipers. How do you get the front fender off touring models. Do I have to remove the front wheel. What needs to come off. I need this info now and I haven't recived the shop manual yet. Help would be great on how to safely remove
Old Jan 10, 2008 | 09:13 PM
eglidetrike1's Avatar
eglidetrike1
Default RE: Front Fender Removal
You have to take the brake calipers off first. Then the wheel.
Old Jan 10, 2008 | 09:24 PM
dawg's Avatar
dawg
Remove the 12 point 10mm bolts that secure the caliper to the forks. Once removed, wrap the calipers in a rag and place them securely over your highway pegs or engine guard. The rags help prevent scratches on lowers or engine guard. You could simply let the calipers hang, but it’s not a good idea because it places stress on the brake lines. Now that the calipers are removed, DO NOT squeeze the front brake lever, as it could force the pistons out and you would need to take apart the calipers to reassemble.
[IMG]local://upfiles/13641/E162CD83E9554E3C987610528297674B.jpg[/IMG]
Old Jan 11, 2008 | 07:17 AM
jbhawley's Avatar
jbhawley
do i really need to say it????
Sure I do!
Buy you a service manual RIGHT NOW!
Old Jan 11, 2008 | 09:08 AM
07blackcherryflhx
It was only a matter of time before it came out. ITS ON THE WAY!
Old Jan 11, 2008 | 09:17 AM
dowhat's Avatar
dowhat
This is the key tool you need: 12 point 10mm bolts
Old Jan 11, 2008 | 11:14 AM
07blackcherryflhx
If you ment socket I just went to sears and picked up a socket.
Old Jan 11, 2008 | 11:32 AM
HDStreetGlide07's Avatar
HDStreetGlide07
When i took my scoot apart to paint it, i didnt have to take the wheel off, i just unbolted the fender and it came right out without any
kind of problems.
Chris
Old Jan 11, 2008 | 11:59 AM
07blackcherryflhx
I have the wheel off now the only problem with taking the wheel off for the first time is that those ugly brake rotors are staring you down and yelling polish me!!!
Old Jan 11, 2008 | 12:02 PM
HDStreetGlide07
Shining up the rotors and doing something with the calipers is on my to do list.
