Installing adjustable backrest
Old Jan 12, 2008 | 12:09 AM
Bluerose
Guest
Posts: n/a
Default Installing adjustable backrest
I'm trying to sting the cable but the bottom drain hole seems to be so far off that I cant fit the hex endthrough...ideas?
Old Jan 12, 2008 | 12:24 AM
Bluerose
Guest
Posts: n/a
Default RE: Installing adjustable backrest
Nevermind...hubby figured it out....
Old Jan 12, 2008 | 01:17 AM
Bluerose
Guest
Posts: n/a
All done Will post pics when i get a chance.
Old Jan 12, 2008 | 05:19 AM
UltraDave's Avatar
UltraDave
You'll love it. I know I did when I installed mine in December. Gave a whole new level of comfort and, I swear, feel in better control of the scoot. Kinda of more part of the bike.
Old Jan 12, 2008 | 11:36 AM
screws4156's Avatar
screws4156
I just installed one on my RG. I should have done this sooner. What a difference. I had a little trouble with the flange nut for the bracket but got it.
Old Jan 13, 2008 | 08:48 AM
earlehd's Avatar
earlehd
Has any one used the heat shields with the adjustable back rest? Could the adjustment lever be reached?
Old Jan 13, 2008 | 07:09 PM
UltraDave's Avatar
UltraDave
I don't believe the heatshields will fit.
Old Jan 13, 2008 | 07:18 PM
Delta's Avatar
Delta
I just finished that installation today on a 2008 Anniversary Ultra. There's enough room between the adjustor and the harley heat shield. It's a tight fit though when tightening the buttenhead bolts. I don't know if the seats are different but the backrest is a pain to insert into the bracket; and when the backrest is folded forward, it really distorts the seat. Guess I got spoiled when I had the Saddleman Road Sofa and backrest on the '04 Ultra.
On another forum someone used a dremel to cut out a portion of the heat shield and inserted the adjustor into the shield. http://forums.delphiforums.com/elect...es?msg=19858.4He used the bracket to trace the outline onto the heat shield.
Old Jan 13, 2008 | 08:18 PM
RonH's Avatar
RonH
ORIGINAL: davewalczak
I don't believe the heat shields will fit.
Actually they fit just fine. Here's a photo of them on my EGC with the adjustable backrest handle in place. Tons of room and easy to reach with the RJ shields on.
[IMG]local://upfiles/9233/2A35C1106C624F53937DB75621195F9E.jpg[/IMG]
[IMG]local://upfiles/9233/1A043E2B36EC4A27ACDDE8D44F3F5B52.jpg[/IMG]
whoop72
Feb 7, 2010 07:27 AM
HOGNOT
Jan 17, 2010 07:55 PM
CFDgrunt
Aug 13, 2008 06:12 PM
Rocket Jockey
May 4, 2007 12:53 AM
capt42a
Apr 19, 2006 01:09 AM
