Gears or Chains
Old Jan 13, 2008 | 10:12 AM
my2004harley's Avatar
my2004harley
5th Gear
Default Gears or Chains
Anyone updated to cam gears? What's the difference and was it worth it?I have 50000 and ready to update.
Old Jan 13, 2008 | 10:18 AM
DonnyI's Avatar
DonnyI
Default RE: Gears or Chains
Worth it.
click here for best price
Old Jan 13, 2008 | 10:19 AM
dawg's Avatar
dawg
50000 dollars or miles? I swapped my 04 FLHTCI to a Andrews 26g gear cam. It was worth it. You need to make sure you have .030 or less crank runout. If you do then it might be worth you doing the roller chain conversion that updates the plate and tensioners. If it were me, I would take it apart (you have to anyway to check the tensioners) and then measure your crank runout. If it is within spec, I would go with a gear drive setup, new lifters, EZ install pushrods and be done with it. What else have you done with the bike, Stage 1, etc? You'll need to do something for fuel management or rejet.
Old Jan 13, 2008 | 10:28 AM
2005UltraNC's Avatar
2005UltraNC
Dawg, need another zero - runout should not exceed 0.003
Old Jan 13, 2008 | 10:31 AM
dawg's Avatar
dawg
ORIGINAL: 2005UltraNC
hehehe, trying to type too fast [sm=youreright.gif]
Old Jan 13, 2008 | 10:45 AM
my2004harley
5th Gear
I have an 04 Electra GlideStandard. Stage 1 kit and Bub True Duals. I love it. No other engine mods. I am not sure my skills are up to the measure part or even the replacement part for that matter. lol
Old Jan 14, 2008 | 05:59 PM
2005UltraNC
Yep, need some special tools and knowledge on how to use them. Dial indicator / mounting assembly, inner bearing puller and installer, plus normal tools. Would rate this like a7 on a 10 scale.
Old Jan 14, 2008 | 06:29 PM
dw2169's Avatar
dw2169
02 Ultra, just had them changed to an Andrews 26 G at 42,000. When the Harley shop got in the found the tensioners shot which took out the oil pump. Lucky for me I had the extended warranty and they covered it plus I got the my new cam installed and now I don't have to worry about it anymore.
Old Jan 14, 2008 | 07:17 PM
bikergeoff's Avatar
bikergeoff
Gears! Did the upgrade to S&S 510's at 58,000 miles. No worries now about tensioners failing.
Old Jan 14, 2008 | 07:53 PM
maineultraclassic's Avatar
maineultraclassic
Well worth it for sure.................no more tensioners to worry about.
I like the very faint whirling sound from them too.............let's people know there is something in there that they don't have.
Steve
