Passing Lamps and Wind Deflectors
Old Jan 13, 2008 | 04:49 PM
Jonny Two Guns's Avatar
Jonny Two Guns
Default Passing Lamps and Wind Deflectors
Has anyone seen these two parts together? I have asked several people at several different Dealerships. The only answer I ever get is "it should" There is nothing in the parts catalog that says yes or no either. Does anyone know for sure and are there any pictures out there?
Willthese two parts work together on my Road King Custom?
[IMG]local://upfiles/46608/712CB35087BC47F2980555C70079A5A7.jpg[/IMG]
[IMG]local://upfiles/46608/F1D8F91FC3194EC4ACBB21234A935867.jpg[/IMG]
Old Jan 14, 2008 | 08:24 AM
Fahpah's Avatar
Fahpah
Default RE: Passing Lamps and Wind Deflectors
Bump, also curious...
Old Jan 14, 2008 | 09:46 AM
I am Jerry's Avatar
I am Jerry
To use them on my Classic I would have had to move the lights to the forward hole. Personally, I don't like the look of them anyway.
Old Jan 14, 2008 | 10:13 AM
ricoman's Avatar
ricoman
Odered a set for my RHC with those same lights and returned them. They do not fit.
Just recently someone told me to try turning them around and doing the install Have no idea if that would work.
Old Jan 14, 2008 | 10:21 AM
Firetender's Avatar
Firetender
No way will it work. The mounting post is right on the side where the deflectors are bolted over. Moving the lights to the forward hole is for those running stock passing lamps which are mounted to the passing lamp bracket under the headlight. Unless your (stock) passing lamps are mounted all the way back in the slot, you don't need to move them forward. The deflectors will just barely touch the back of the passing lamps, and you can still clean them.
Old Jan 14, 2008 | 11:22 AM
ricoman's Avatar
ricoman
I know they won't work out of the box.
Didn't sound right to turn the deflectors around.
Too bad, I would like to have them with my lights.
Gfroh
38
Apr 16, 2021 11:42 AM
Cmac69
Touring Parts
13
Mar 10, 2019 05:14 PM
Jclind1966
EVO
13
Apr 7, 2015 03:39 PM
Good_Apollo
Dec 19, 2010 06:17 AM
