OK, I keep my bike well poliched, however, when cleaning up the chrome on the engine, there are some white spos on the black textured surface of the block/cooling fins. Tried to clean up ASAP w/ a brush, but you can still seeit. Any sugggestions how to remove the polish from the black textured surface?
I usedSIMPLEGREEN on mine. Put it in with a stiff nylon brush. It got lots better, but still showed a bit. Then again, mine was like a giant terd onaconna it dripped down from above.
Big 'l white glob of wax.
Anyway, finally can't see it at all, and did not hurt the pourous black.....
Mine came back from the dealer with some white wax spots on the black of the engine cases,i used a tooth brush to scrub it off ,and sprayed the S-100 engine brightner to cover the rest ,worked great!
