reduced effort clutch kit
Old Jan 15, 2008 | 05:44 AM
jbmss's Avatar
jbmss
Default reduced effort clutch kit
has anyone have the Reduced effort clutch kit in there bike? I am thinking about installing one in my 2005 E -Glide.is there a differance in the clutch pull over stock?
Old Jan 15, 2008 | 06:14 AM
1SG's Avatar
1SG
Default RE: reduced effort clutch kit
one of the best upgrades I've done.You will like it. The hardest part about installing it is getting past the exhaust. If you have a 95" or bigger motor you may not be able to use the spring (clutch might slip) mine did, howerever I still installed the ramps and that made a difference (easer to pull) This forum has several posts on it, do a search. Well worth the money and time.
Old Jan 15, 2008 | 07:07 AM
1flhtk4me's Avatar
1flhtk4me
Well worth it on a stock bike.
Old Jan 15, 2008 | 07:13 AM
Peppa1's Avatar
Peppa1
Had 03 EGC and when I upgraded to an 06 where the easy ckutch was standard it was a noticeable difference. You like it.
Old Jan 15, 2008 | 07:22 AM
Windup08's Avatar
Windup08
Put it in my 02 Dyna....first time I pulled the clutch in I thought the cable was broken....well worth it.
Old Jan 15, 2008 | 07:36 AM
Harleypingman's Avatar
Harleypingman
Very noticeable change, though I couldn't give you a percentage.
Old Jan 15, 2008 | 07:41 AM
bucs012's Avatar
bucs012
About how much cost are we looking here? I have an 07 RG but my 05 Deuce sure would be nice to have the easy clutch pull!
Can most do it on their own with a service manual or is it something for the stealer to do?
Old Jan 15, 2008 | 11:09 AM
GTK's Avatar
GTK
First time you in a traffic mess,you will really appreciate the easy pull of the clutch lever.
Old Jan 15, 2008 | 11:15 AM
eglidetrike1's Avatar
eglidetrike1
Easy upgrade to do.
Old Jan 15, 2008 | 11:48 AM
BirchwhiteHD's Avatar
BirchwhiteHD
I had the SE 1550 big bore done a couple years back,they installed the heavy clutch spring,didnt mind it to bad except in traffic.I had the easy pull installed while it is in winter storage,stopped in a few weeks ago to see if they had installed it, as someone stated above,they thought the cable was broken,i felt the same way. my bike still has the SE heavy clutch spring installed,and i cant beleive i waited so long to have this done,it's almost to easy to pull,will be a pleasure in traffic ,compared to what i was used too.
