Anybody heard about this? Apparently all touring models manufactured in December 2007, and afterwards, have this system standard. It's basically the same as the dealer downloded "parade mode", which shuts down the rear cylinder if the engine temperature reaches a certain level, such as when crawling in stop and go traffic. The EITMS in the new bikes, is installed already, and can be turned on or off by the operator, with a throttle turning sequence, while engine is off, and ignition in the run position. The engine will resume normal operation, as soon as the temp reaches the safe level, or the throttle is twisted past a certain point, or if the tranny is in gear and the clutch is released, or if the speed exceeds 1 or 2 mph. I'll try to find the link to the bulletin, and I'll post it later.
You can turn it off and on with the SERT. The dealer can turn it on and off with the digital technition. Not sure it can be done with any throttle turning sequence though.
unless your in Az. in August, at 105 degrees, and in a 2 mile long parade, which has stopped for a 6 mile long train,,this feature
rarely kicks in,, but hey,, if ya think parades are your thing,, get the download
It looks like earlier '08's can get there ECM flashed to allow them to do this also.
It's a one time in and out if you don't like it for free. After that the customer pays.
Not any more. If you look at the attachment that Kroozer posted it looks like you down load the free revision and after that you can turn it on and off at will. No SERT, no digital tech, just a simple throttle sequence. [&:]
That's how I read it. Makes me think the MoCo must feel it is somewhat important if they are making it user selectable on all bikes now.
