forward facing intake
Old Feb 2, 2008 | 02:20 PM
DrBob81's Avatar
DrBob81
Default RE: forward facing intake
I've had 2 dyno tuners tell me that without the bigger throttle body, you will not get more flow, but if you like the look, what the hec.
Old Feb 2, 2008 | 02:23 PM
monkish's Avatar
monkish
Those are all some good looking intakes. Thanks for the input. I think I'll go down to Harley and check out the heavy breather. I want to see it in person.
Old Feb 2, 2008 | 02:32 PM
Doc Intrepid's Avatar
Doc Intrepid
From: In the Pacific Northwest, a few hours east of Seattle.
ORIGINAL: linck241
I think the looks of these filters are bad a@# but I have a concern about them and it is why I have not bought one so with that said I have a stupid question.
What happenes if you get caught in the rain or stuck in wet driving conditions with one of these??
Will all that water get sucked into your motor??
Please take this comment in the "for what its worth" department.
I don't pull apart my own motor, I don't rebuild motors, and I'm only passing along heresay. But these remarks came from a Harley tech who DOES rebuild engines.
I asked the same question about both the 90s with filters and the open stacks. What I was told was they they work great on show bikes and bikes that are not ridden in the rain. But if you're touring or setting up your bike to ride in all weather, then yes - they will allow more moisture inside the engine than the sheltered air intakes.
While it may not be enough to "drown out" the engine, the point that they made was any time you have residual water inside the engine there is a potential for damage to pistons, valves, cylinders, etc.etc. He also noted that the open stacks allowed dust and road grit inside the engines on touring bikes.
So for bikes that wouldn't be ridden in the rain - go for it. For touring bikes that will be ridden in all kinds of snow and rain or tough weather conditions, not a good idea.
I'm sure if that was incorrect advice some of you guys who work on your own engines will correct me!
Doc
Old Feb 2, 2008 | 02:42 PM
etrader's Avatar
etrader
Takes 10 seconds to slip fitted rain covers over the filters.
Old Feb 2, 2008 | 04:40 PM
monkish's Avatar
monkish
Went with the S/E Heavy Breather. Went down to HD and they actually had put one on one of the bikes in the show room. It looked great. Thanks for the input.
Old Feb 2, 2008 | 05:28 PM
Tinkermc's Avatar
Tinkermc
hey Monkish, did I tell ya how good ya look in PINK !!!
Old Feb 3, 2008 | 07:49 AM
monkish's Avatar
monkish
ORIGINAL: Tinkermc
You ought to see me in by bikini [sm=happybounce.gif]
Old Feb 3, 2008 | 08:09 AM
biz44's Avatar
biz44
I have read although I dont recall where, that of the 90* intakes systems the HD SE-Heavy Breather has the largest filter surface area giving it the potential to move the most CFM, but that is still limited by the diameter of the intake manifold. So if your looking to move much more air, you would have to modify the entire intake tract....from the filter all the way to the intake valve....IMHO.
If your looking to improve the performance of the intake a bit with something that looks nice....the 90* units do just fine. I know that most do come with a fitted "rain sock" that will help with keeping water out.
Old Feb 3, 2008 | 03:55 PM
MCSarge's Avatar
MCSarge
I am going to pick up the HD heavy breather next week. I was told as long as I had the Stage 1 download and had already installed that airfilter the heavy breather would work fine with out any other changes. When I get the new S&S cams in I will have dynoed to make sure I'm getting the most of the motor. Good luck with your choice.
Old Feb 3, 2008 | 04:10 PM
monkish's Avatar
monkish
ORIGINAL: MCSarge
I just had a set of HQ TC-500 cams put in and had it all tuned. It runs great but the tune is still off and after some conversation on here I have decided to let someone else tune it before I do anything else. I have talked to T-Man in Kernersville, NC and although he wished I would have come to him first, he is going to get my bike right. Since he is going to tune it next week I figured I would put the Intake on now also. I have already decided to let him do all the work on my wifes bike when we get ready for that. I was actually going to let him go ahead and take mine to a 107 and he suggested that we just tune it and get it right first, and then I could see what kind of work they do and move forward from there with the wifes bike before I spend anymore money on mine. Then I could compare his setup with what I did to mine already. Pretty good advice I think. I can hardley wait to get the breather and a good tune, it should be nice for just a mild upgrade.
