Screaming Eagle Pipe ?
Old Feb 5, 2008 | 08:33 AM
ROLLNTIGER's Avatar
ROLLNTIGER
Default Screaming Eagle Pipe ?
The 03' Ultra I just bought has aftermarket pipes installed. The guy I bought it from said he had the stage 1/download done. The bike sounds awesome but I have looked all over the pipes to see a manufacture brand but can't find one. Did the older Screaming Eagle pipes have any markings? They do have removable end caps and I want to change em out to fishtails but want to make sure they are SE?
Old Feb 5, 2008 | 08:37 AM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: Screaming Eagle Pipe ?
As far as I can remember the SE Mufflers\Slip-ons have always had the Eagle in the muffler\slip-on
Old Feb 5, 2008 | 08:40 AM
ROLLNTIGER's Avatar
ROLLNTIGER
I have added a larger picture to show more pipe... These don't have any markings at all?
Old Feb 5, 2008 | 09:12 AM
bobbyg12's Avatar
bobbyg12
Rush mufflers are usually unmarked. I have also heard (unconfirmed) that SE end caps will fit some Rush models. Good Luck!!
Old Feb 5, 2008 | 10:07 AM
rm4040's Avatar
rm4040
My understanding is that the Super Trapp SE is the same 2 piece muffler as the HD SE. You will be able to get the end caps from them if HD doesn't have any.
Old Feb 5, 2008 | 11:17 AM
bear95's Avatar
bear95
If you take the bag off and look by the mounting bracket there should be a part number there that you could check. I bought my bike used as well and it's supposed to have screaming eagle pipes on it but they don't say screaming eagle on them butIthink that they are.
Old Feb 5, 2008 | 11:32 AM
Elusive 1's Avatar
Elusive 1
The marking might be on the inside, the old screaming eagle'sare the same as the SuperTrapp SE.s and you can mount with the marking in or out. SuperTrapp made the Sceaming Eagle II's for HD.
Old Feb 5, 2008 | 11:35 AM
IronLegend's Avatar
IronLegend
The SE's that came on my '02 didn't have a Scream'n Eagle script I don't think. The only markings I remember noticing were thepart#'s (different one on each muffler) and some wording to the effect that they were intended for closed circuitcourse use, I thinkmine are the racing ones.
Old Feb 5, 2008 | 11:50 AM
ROLLNTIGER's Avatar
ROLLNTIGER
ORIGINAL: bear95
I pulled the bags and looked by the bracket. Nothing? No SN#, no part# or anything? I was able to remove the end caps they are 3" in dia. and they have a single hex head screw on the bottom. Oh and the baffles are welded in, non removable..
Old Feb 5, 2008 | 03:25 PM
ROLLNTIGER's Avatar
ROLLNTIGER
Well I brought the end caps into the dealer and the parts guy seems to think they are Sampson pipes. Any body got Sampson's
Willetts1
May 26, 2010 11:23 PM
chadw8434
Aug 27, 2008 05:15 AM
fbjunior
Aug 24, 2006 04:32 PM
sporty2003
Mar 22, 2006 02:39 PM
carver
Mar 10, 2006 04:26 PM
