DIY Harley Bluetooth
Old Feb 6, 2008 | 10:43 AM
homehandyman's Avatar
homehandyman
Default DIY Harley Bluetooth
I realize I may get flamed here however I got to ask. Has anyone done the Harley optional Bluetooth harness install themselves? I understand about the additional harness (70164-06). Is this something that I can install myself or should I have Dealer do it. Dealer said about 2 1/2 hour install (labor) to do it. I am somewhat mechanical, however I have never worked on a bike. Only cars.
Old Feb 6, 2008 | 04:09 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Default RE: DIY Harley Bluetooth
How hard could it be? I'd probably do it myself, but then I'm cheap.
Old Feb 6, 2008 | 04:12 PM
liltrk's Avatar
liltrk
If they are saying 2 1/2, you can probably do it in under 2.
Old Feb 6, 2008 | 04:55 PM
Tinkermc's Avatar
Tinkermc
I would do it myself
Old Feb 6, 2008 | 05:12 PM
gene01's Avatar
gene01
I have done it, if you have the tools and a little know how, you can do it in 2 hours or less..... you need to remove the seat, the fairing, run wire through the tour pak under the seat, under the tank into the fairing, you will assemble a plug to plug into a wiring harness, you will take an additional pair of wires red and black to plug into another existing harness .... by the way, you need to buy another wiring harness that is not included, there are 2 versions, if you ever intend to install xm radio, buy the 2 product harness otherwise you will need to replace the slightly cheaper harness later to upgrade.... you will love this option, it will adopt your phone book and works great...
Old Feb 6, 2008 | 11:57 PM
homehandyman
Thank You to everyone for your responses.
Old Feb 7, 2008 | 12:02 AM
homehandyman
Does the shop manual discuss installs like this?
dfndr
Sep 24, 2011 11:34 AM
marcortez
Sep 13, 2011 12:10 AM
tomlescal
Apr 25, 2010 04:49 PM
wkenddad
Nov 12, 2008 03:24 AM
avacado
Jan 11, 2007 12:11 AM
