Adjustable Drivers Backrest
Old Feb 10, 2008 | 09:27 PM
roadgeek's Avatar
roadgeek
Default Adjustable Drivers Backrest
Does the mounting bracket screw and nut go into the hole where the cruise control cable was?
If so the nut will fit there because of the frame.
PLEASE HELP.
Old Feb 10, 2008 | 09:35 PM
1atom12's Avatar
1atom12
Default RE: Adjustable Drivers Backrest
Yes, that's where the mounting bolt goes. It's a real bitch to hold that nut still while you tighten it... Maybe someone has another suggestion, but that's how I did mine... Good Luck.
Old Feb 10, 2008 | 09:41 PM
roadgeek's Avatar
roadgeek
I am wondering if the hole was drilled to close to the frame because the nut will not fit over the hole. The frame is in the way.
Old Feb 10, 2008 | 10:40 PM
hogdoc's Avatar
hogdoc
There is a self tapping screw in the hardware bag, use it instead of the bolt and nut. Some frames you have to open the hole up slightly to get the self tapper started but once you thread the frame with install the bracket. Much easier than the bolt and nut!
Old Feb 10, 2008 | 10:56 PM
roadgeek's Avatar
roadgeek
Thanks that worked.
Old Feb 11, 2008 | 05:08 AM
screws4156's Avatar
screws4156
That the right hole. and Yeah it was a pain to get that nut in place . I used a pair of 12 inch forcepes.
Old Feb 11, 2008 | 06:55 AM
roadgeek's Avatar
roadgeek
along with putting a rag in the hole, so when you drop the nut it doesn't take a 1/2 hour finding it.
Rev. Dr. Tom
Mar 27, 2013 06:25 PM
Keithhu
Dec 8, 2012 11:13 AM
mkguitar
Jan 20, 2012 12:57 PM
Shadew
Dec 28, 2011 08:48 AM
fatbob
May 24, 2008 06:38 AM
