Floorbard Extension question
[IMG]local://upfiles/46392/0BB1E198CE1C4434BB1A885E3F7818C3.jpg[/IMG]
It hasn't been a problem so far, the comfort factor is well worth it to me. Guess I got used to the scraping....
I have the extensions from Kury and they give about 3/4" more room. I have not found the reduced cornering clearance to be a problem, but if you think through the math it seems that there is some reduction at the most extreme lean angles. But that's OK, because the footboards are hinged and there isn't any danger of lifting the wheels off the ground.
After the running board hinges, the bracket picks the bike up off the ground, I did the math and it was quitethe feeling. For some reason the brackets are getting worn on my bike.
http://www.meancitycycles.com/
if you want to change shocks and get lower you may want to go $1000 ish adjustable air ride.
Here is my question....with these installed will the floorboards scrape more easily?
Mine are still stock,I don't scrape real often, and so far it's only been enough to make some noise and fold the board up a little. Therefore (thanks again y'all) I'm going to go for itbut I want to extend mine FWD some too - 34' in-seam.
Naturally I'm looking at the "soos setup"but posted a question the other day about that new Kury set that does both 1" OUT and1" FWD. Not on the street yet and no infoso far but still going to think some.I prefer a one-piece setup rather than stacking 2 gizmos up on top of each other - just more pieces to get loose.
Yes indeed - good question and thanks all for thefeedback.
https://www.hdforums.com/m_2879529/tm.htm
They're more expensive than soos for surebut then machining is more complex plus they'rechromed. However,I would prefer black. Can't see paying for chrome on F/B support brackets myself.
