EXHAUST SQUEAK ????
Old Feb 17, 2008 | 12:17 PM
lecomte38's Avatar
lecomte38
Default RE: EXHAUST SQUEAK ????
$1.85 each - spring for a pair
Old Feb 17, 2008 | 12:19 PM
celltech's Avatar
celltech
I just fixed this exact same issue on my RK by using a 1.5 inch piece of flat metal and forcing it in between the rubber bushing thing and the metal mount. It's been two weeks and the squeak is no where to be heard.
Old Feb 17, 2008 | 12:38 PM
beary's Avatar
beary
This is a very timely question. My 02 RKC just started doing the same thing on my last ride. It is a surprisingly loud sqeak. I'm glad its not just me.
Beary
Old Feb 17, 2008 | 12:57 PM
bikergeoff's Avatar
bikergeoff
My hanger does this from time to time on my 2-1 pipe. I just use a little wheel bearing grease, seems to last about a month or so, unless I'm in a lot of rain. I tried replacing, new bushing was squeaking within days...
Old Feb 17, 2008 | 05:56 PM
hogdoc's Avatar
hogdoc
ORIGINAL: electaRICK
left side,,,, right???
they all do it
Just switch the left side to the right and the right side to the left,........worked for the rotors!
Old Feb 17, 2008 | 06:38 PM
krgs2k's Avatar
krgs2k
I just lube mine up every now and again with spray lithium grease. Something
you just have to get used to.
Old Feb 18, 2008 | 07:43 PM
wideopen1967's Avatar
wideopen1967
I used some really potent two part silicone adhesive (dont ask where to buy I got it from work I work in appliance manf) I have actually bonded the braket into the rubber mount. I will keep ypu posted.
Old Feb 18, 2008 | 08:14 PM
GliderXXX's Avatar
GliderXXX
I like the washer or penny idea. I use to take a small piece of cloth and wedge it in firmly with a flat head screwdriver. Thats all it took. No squeak once you secure the bracket more firmly to the rubber.
Old Feb 18, 2008 | 08:18 PM
Geoff's Avatar
Geoff
A shot of lithium grease or silicone spray should solve the problem.
Old Feb 18, 2008 | 08:29 PM
skateboard's Avatar
skateboard
Mine squeaked when I changed mufflers.I loosened the clamps and straiten the muffler and it's worked for a year now.[/align]
