Nice work. I was going to suggest some diamond plate. Maybe I'll keep that on for my self. Now I just need to get some floorboards....Please post your final write up in the DIY section.
I have them and they're very well done. In fact, the seller accepted my request to skip the grooves and do a solid set for me - no sweat.
If I had anything to complain about, the backside surface sits on top ofthe existing "ridge-line" and there's no "over the edge" type of lip on the new guys so I justdid what the instructionssaid, use a markie-pen and black-out the existing drab silver ridges so that no little snippets of silver paint are visible anywhere around the edges. Looks fine too but no camera so no pics though - sorry.
This idea receives the official Uncle Scrooge seal of approval. Another material that might work is aluminum roof flashing available at Lowes or Home Depot.
Great idea. I wonder if 3M tape would work instead of screws? Some may think about diamond plate instead of plain aluminum or stainless.
Lotsa possibilities.
hey i got a stupid question. i KNEW there had ta be a way to transfer a pic from your cell to the puter but no one i know can tell me how ta do it.????????????i have a motoraola razor and the cord off my camera fits the phone and puter but nuthin happens.what am i doin wrong??????????
Thanks, after reading this I used some silver paint around the inside edge of themachined lip. My template is real close but isn't exactly perfect. You could see a touch of black in a couple spots. Looks cut perfect now, great idea!
I also cut out the 3M tape on the back where the screws are so the plate sits perfectly flat against the board. I haven't attached the inserts because the garage is a little cold and want the tape to stick good. I'll wait till I get the garage a little warmer. Try to take a good pic with my other camara when I stick them on later! Thansk for the props guys!
After you connect it up.. Click on "My Computer" See if yiou have a "Removable Disk" other than C: If ya do ..then click it... You should see it if it's a Razr.. (If you connect it to a laptop..it will charge it at the same time as well..)
Now back to the thread...
We can't use our old plates here.. WisDOT still uses the old STAMPED type plates....
