laid it down this weekend
Old Feb 18, 2008 | 12:03 AM
koga's Avatar
koga
Default RE: laid it down this weekend
Make sure you check where the crash bar secures to the frame, buddy dumped his and it turned out the frame was bent, (On an 01 Ultra)
Old Feb 18, 2008 | 12:10 AM
SoCal_Pappy's Avatar
SoCal_Pappy
CRASHIN SUCKS... But turn it over to your insurance company...
Ft Crash Bar $200.00
Hard Bags $1500.00
Floorbrd bracket & floorbrd $167.00
If you hit the engine guard I'll bet you also taged the Saddlebag Guards also and s muffler or two... I would bet your damage if you look real close will exceed $2000.00 easy...
Old Feb 18, 2008 | 12:23 AM
Arizona's Avatar
Arizona
Well sorry to hear about the mishap, but glad you're here to tell us about it and heal up fast...
Old Feb 18, 2008 | 12:35 AM
Bluerose
Guest
Posts: n/a
It really does add up quick. Just having my bike on its side (all minor but the tour pak..long story). I insurance replaced every little scratch...came out at $1600....Which was the tour pak (bucket/lights/hinges only), bag guard, crash bar, and just the painted section of the lower fairing.....
Consider filing an insurance claim...if it is someone else's fault file against them...
Old Feb 18, 2008 | 06:03 AM
rocknrod's Avatar
rocknrod
ORIGINAL: choochoo
Don't even try to straighten the crash bar. Just get a new one.
Your bags are not fibre glass.
They are a type of abs plastic.
If minor crack it can be welded with a plastic welder if anyone in your area does it.
Major crack, buy new or used one and repaint it
Too bad about the lay down
http://www.harborfreight.com/cpi/cta...emnumber=41592
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
And oh by the way Eastwood has alot of other stuff too. Even home powdercoating stuff.
Old Feb 18, 2008 | 06:19 AM
SG Mike's Avatar
SG Mike
ORIGINAL: Yogibear
Can't say about the body work but I wouldn't try and re-use the crash bar. It's not intended for "multi" usage.
later..........
+1 on that quote! That's why you buy insurance.
Mike
Old Feb 18, 2008 | 07:34 AM
Badfinger's Avatar
Badfinger
[quote]ORIGINAL: rocknrod
[quote]ORIGINAL: choochoo
[quote]
Sorry about the fall! I've welded PVC pipe with a similar welder and you have to use "like" material. The Eastwood system looks interesting and may be your best bet if you try to weld. You would need to lay the bead on the inside as you don't grind or sand any off for strength. They have universal rods. I don't know what damage the heat would do to your paint in any.
God luck,
Jim
Old Feb 18, 2008 | 07:41 AM
Puzzled's Avatar
Puzzled
Now is the time for some upgrades. Linby crash bar, Stretched bags.......
Old Feb 18, 2008 | 07:52 AM
choochoo's Avatar
choochoo
I would venture to say the downtubes and neck wer not bent.
The small hoizontal metal plate that the crashbar mounts to below
the neck probably was.
Granted being welded to the frsme it makes it part of the frame.
I took a very hard hit back in 02 (blacked out). Went airborn did
a 360 barrel roll(witnesses). Completely totaled bike.
Stripped it down and took to three shops to verify straight.It was
so I reused it.
That metal tab can be bent by pushing too hard with feet on the bar
or just falling over off the kick stand.
But granted I haven't seen your buddies.
ORIGINAL: koga
Old Feb 18, 2008 | 07:56 AM
Tenn's Avatar
Tenn
the bikes are easier to fix than our body....
i had a pucker factor 7 this weekend while riding two up going 60+ a car pulls from the right, broadside then stops when he figured out he messed up. well i lock em up got alittle sideways head into the grass median get back on it and somehow kept going.
my first thought was to turn around and get this a-hole......i didn't. maturity i guess.
be safe
TN
