Yuasa makes most of the OEM batteries, including HD, and they're a very respected name in powersports batteries. Knowing that might get you the exact same battery for less money.
The service you get from a battery depends a lot on how it's been treated. Make sure you get a fresh one that hasn't been sitting on a store shelf for a year or two, and use a battery maintainer if it sits for a month or longer over the winter.
GENERALLY HD BATTERIES ARE JUNK.. WHEN THEY GO (APPROX 2 TO 3 YEARS DEPENDING ON HOW WELL U TAKE CARE OF THEM) I GO FOR A DIEHARD FROM SEARS.. LESS EXPENSIVE AND IMO A MUCH BETTER BATTERY..(MUCH LONGER LIFE) THAT SAID MY 03 ULTRA ( DELIVERED 11-02) STILL HAS THE ORIGINAL BATT ????!!!
THINGS THAT MAKE U GO HMMMM
Agree on that 100%. The Diehard from Sears is made by Delco for Sears and you get it at a better price. I believe it's a 5 year battery.
Yuasa..good quality battery, have had good results with them. Cross reference to HD, exact fit and much cheaper. I seriously doubt that HD "makes" their own batteries. Probably Yuasa, AC Delco or Interstate makes HD batteries if we are lucky..if not probably offshore from China or Mexico.
Later
Oddessy the only way to go they are great people there. I run there Batt. in every thing i own and have had no problem I run it in my Spec. Sprint. It has lasted 3 years so far.
