'07 final drive ratio change?
Old Feb 23, 2008 | 02:04 AM
RangeRat's Avatar
RangeRat
Default '07 final drive ratio change?
As far as I'm concerned,6th gear is just not very usable anywhere except on an Interstate and I spend a lot more ride-time at 55-60 MPH. Therefore I'm thinking about lowering the final drive ratio a little bit so that RPMis up a tad and actual rear-wheel torque is a bit higherin all the gears.
Has anyone played aroundwith comp gear/clutch gear ratios or pulley sizes on an '07? Heck.... are there even any alternatives for an '07 when I don't want a BIG change - just a few hundred more RPM/MPH in 6th?
Steve
Old Feb 23, 2008 | 04:25 AM
radridd's Avatar
radridd
Default RE: '07 final drive ratio change?
Just keep it in 5th. Thats what I do except for 65-70 +.
Old Feb 23, 2008 | 05:53 AM
dawg's Avatar
dawg
Either do what some of us have done/are doing and get a 30 tooth sprocket and chain and do away with the compensator or change out the tranny sprocket on the other side and get a new belt
Old Feb 23, 2008 | 08:16 AM
OldPhat's Avatar
OldPhat
Andrews Products makes a 30 tooth trans pulley
rmc115
Feb 23, 2009 06:04 AM
garyw
Apr 15, 2008 10:31 AM
Vettepro
Mar 23, 2008 08:36 PM
My427stang
Oct 1, 2007 10:12 AM
shepo
Mar 5, 2007 01:55 AM
