Over the weekend, I bought the smart siren II with the little antenna, and installed it into the left electrical caddy per the service manual. Siren works fine.
I tried to encode the battery operated smart pager II to the bike, but the pager instructions say to put the pager into encoder mode (ok,easy enough), and then arm the bike security system using the fob remote. The catch is, my bike has the automatic buttonless/keyless security system. I tried turning the ignition on, putting the pager into encoder mode, and turning the ignition off. The signals flash, and the siren chirp chips, but I can't get the pager to encode.
Follow the instructions just as they are, these are actually written correctly. You have have to follow a sequence w/ the ignition; I just did that exact set-up two weeks ago. I was actually surprised how easy it went.
Huh? My instructions mention nothing about doing stuff with the ignition. In fact, the last rev date on the instructions was in 2005. I'll bet the jackass dealer parts morons sold me the wrong crap.
The alarm systems changed in 07 I believe. You're probably right about them selling you the wrong part. Don't let them give you any BS about not taking back electrical parts either.
The Smart Siren II Part # looks like it's the same for 2002- 2008 Touring Models in the accessory catalog. The Part # is68328-06.
Didn't know that the pager worked with the keyless system. Mines a 2006 and they came out with keyless in late 2007. I think it was originally called under the brand name Security Dawg. If it sets up the same, you have to start setting it before it times out.
You almost had it. Here are the instructions for bike with hands free FOB (I think you have an old instruction book)
1. Turn ignition off.
2. Turn pager off
3. Press and hold button on pager until lights flash and pager starts to beep.
4. Turn ignition on, then off. Pager should beep four times.
