Chrome Regulator Cover?
Old Feb 27, 2008 | 04:46 AM
rocknrod's Avatar
rocknrod
Default RE: Chrome Regulator Cover?
Well I may have screwed up, but I hated looking at it. So I bought the actual chrome regulator instead of the cover.
Old Feb 27, 2008 | 04:49 AM
xxxflhrci's Avatar
xxxflhrci
I have a friend who has owned an indy shop for 20 years. He claims that out of all the regulator failures he sees, most of them are on bikes with covers. He swears the covers hold in extra heat and kill the regulator.
Old Feb 27, 2008 | 05:05 AM
screws4156's Avatar
screws4156
It was the 1st chrome cover I put on. No Problems
Old Feb 27, 2008 | 05:25 AM
XTrooper3936's Avatar
XTrooper3936
ORIGINAL: Retired_Ted
The chrome defeats the purpose of the black color and the cooling fins on the regulator.
Restricting air flow over the cooling fins I understand, but what would the purpose of the black color be? Last I heard, black absorbs heat more than light or reflective colors do, so its dark color will, if anything, make it run hotter.
I'm sure the chrome cover does restrict air flow to some degree and, consequently, will have "some" effect on the life of your voltage regulator. That said, I doubt longevity is affected much as I've known voltage regulators to last for years even with a cover on them.
I think the chrome-plated voltage regulator is the best way to go. With it, you get the look with no air flow restriction. The downside is that it's a little pricey at $170. Of course, if you buy a chrome one, you can stow the stock one in a saddle bag as a spare.
Old Feb 27, 2008 | 05:31 AM
DaveMK's Avatar
DaveMK
Of course, if you do lose your regulator, it'll only happen in the middle of nowhere and at night. Hope that helps - have a nice day .
Or on a Sunday.
Old Feb 27, 2008 | 04:16 PM
Retired_Ted's Avatar
Retired_Ted
ORIGINAL: XTrooper3936
A black body not only absorbs more heat than one that's not black, but, it also radiates more heat. Think about it - what color is the radiator in your car? I'll bet it's not chrome. Look at the headers on a racing engine - bet they're not white (or at least they shouldn't be). There are lots of references regarding this principle - click >>>HERE<<< for a discussion, if you like. Also, have you ever seen the little toy called a RADIOMETER - it's a case in point. Radiators that are supposed to dissipate heat (and voltage regulators) should always be left black or you'll increase the chances of failure (38 year HD mechanic's advice, not mine).
Old Feb 27, 2008 | 05:05 PM
rome304's Avatar
rome304
over a year now no problems so far had not heard that.
[IMG]local://upfiles/22213/3C7B9DB22825475597CC55B4F3BDE55A.jpg[/IMG]
Old Feb 27, 2008 | 05:32 PM
XTrooper3936
Thanks for the lesson. It just goes to prove that even at my age, you're never to old to learn something new.
Old Feb 27, 2008 | 05:52 PM
jimmy z's Avatar
jimmy z
One of the first chrome pieces I put on.So far so good.
Old Feb 27, 2008 | 06:32 PM
stro1965's Avatar
stro1965
Hmmm....me thinks I might pass on this and pick something else to make shiny.
